L3GD20
L3GD20
2,051 次查看
omarvallecasas
Hi, did someone worked with L3GD20 Gyroscope on Freescale microcoutrollers? I'm having a issue when configuring. I'm using KL26Z128 by SPI0. Please if someone had a experience with these devices, could you share it?
Thanks in advance,
Omar
1,862 次查看
Hui_Ma
We don't have available L3GD20 chip example code.
Please check attached  KL25 SPI example code.
Wish it helps.
Ma Hui
1,862 次查看
omarvallecasas
Hi Ma Hui,
Thanks for your quick answer. I'm using KL25 SPI most likely to KL26 configuration for SPI, but it match with the one I was using. I send a 16 pulse clock signal with automatic CS to the L3GD20 (Gyro), MOSI signal is generated but MISO signal not, I only get noise. I recently buy the Gyros (10 pieces), with 22 FRDM-KL26Z just to do Sensor Fusion for motion tracking.
Omar
