Kinetis L Source Code KL25_SC.exe
3,749件の閲覧回数
erwinw
I am having failures when trying to extract the KL25_SC.exe file from 9/24/12. The following error occurrs on Windows XP machine
I have tried and download the file a few more times and rebooted the mahcine before trying to extract but to no avail. i am unable to pass this error.
Your help would be greatly appreciated.
ラベル(2)
2,888件の閲覧回数
toñohernández
hi Erwin,
When did you download the Sample Code?
Could you please try one more time from http://www.freescale.com/files/32bit/software/KL25_SC.exe
Let me know how it results
3 返答(返信)
2,889件の閲覧回数
toñohernández
hi Erwin,
2,887件の閲覧回数
arthurmanning
This did not work for me, and I have the same problem.  I have downloaded this self-extracting program several times with the same result.  Is it possible for them to put the sample code in a more standard format, such a zip archive?  Some of us use Macs or Linux machines, so Windows-only executables are not the best way to promote your fine products.
2,887件の閲覧回数
erwinw
That code worked fine. Thank you!
