Kinetis L Source Code KL25_SC.exe
erwinw
I am having failures when trying to extract the KL25_SC.exe file from 9/24/12. The following error occurrs on Windows XP machine
I have tried and download the file a few more times and rebooted the mahcine before trying to extract but to no avail. i am unable to pass this error.
Your help would be greatly appreciated.
toñohernández
hi Erwin,
When did you download the Sample Code?
Could you please try one more time from http://www.freescale.com/files/32bit/software/KL25_SC.exe
Let me know how it results
toñohernández
hi Erwin,
arthurmanning
This did not work for me, and I have the same problem.  I have downloaded this self-extracting program several times with the same result.  Is it possible for them to put the sample code in a more standard format, such a zip archive?  Some of us use Macs or Linux machines, so Windows-only executables are not the best way to promote your fine products.
erwinw
That code worked fine. Thank you!
