Kinetis K65 internal flash write-erase cycles
已解决
跳至解决方案
1,882 次查看
MattJCole
Contributor V
I plan to write data to flash if I lose the ability to write to the SD card. What is the maximum number of write/erase cycles can do on the Kinetis K65?
1 解答
1,860 次查看
jingpan
Hi @MattJCole ,
K65 cycling endurance is 50k for typical and 10k for minimum. Please see table 25 in datasheet.
Jing
在原帖中查看解决方案
1 回复
1,861 次查看
jingpan
Hi @MattJCole ,
Jing
