Kinetis K65 internal flash write-erase cycles
1,887件の閲覧回数
MattJCole
I plan to write data to flash if I lose the ability to write to the SD card. What is the maximum number of write/erase cycles can do on the Kinetis K65?
1,865件の閲覧回数
jingpan
Hi @MattJCole ,
K65 cycling endurance is 50k for typical and 10k for minimum. Please see table 25 in datasheet.
Jing
1,866件の閲覧回数
jingpan
Hi @MattJCole ,
Jing
