Kinetis K22 TWR-K22F120M + TWR-SER2 USB High-Speed
1,906 次查看
nbgatgi
Does the enhanced serial tower board (TWR-SER2) make high-speed (HS) USB possible with the Kinetis K22 tower board (TWR-K22F120M)?
标签 (2)
1,777 次查看
mjbcswitzerland
Specialist V
Nick
The K22 has full speed OTG and not HS USB so it can't be used with the HS tranceiver on the SER2 board.
You will need a K26 for HS USB.
Mark
1,778 次查看
mjbcswitzerland
Specialist V
Nick
Mark
