I just went through the solution advisor to get a .csv of the Signal Muxing section for the MK60DX256VMD10 part.
When going through the Solution Advisor generated mux table, I noticed that it has additional ALT's listed that the data sheet does not.
I am using the K60P144M100SF2V2 data sheet, Rev 2, 12/2012.
For example:
Solution Advisor Mux table has L9 : PTA11 : ALT5 = FBb_OE_b
The data sheet has no entry for L9 : PTA11 : ALT5.
So, which is correct?
解決済! 解決策の投稿を見る。
The correct pinout is the one depicted in the Datasheet and Reference Manual
