Windows SDA-CDC port driver installation
marcelo_freek
I know it sounds pretty silly, but I just can't get my freedom board drivers recognized by windows. Neither XP nor 7 64 bits.
I downloaded the driver files from P&E, but when using device manager to update the driver when windows detects it, device manager just do not recognize driver files.
Any hint ? I searched forum messages but nothing came up.
Marcelo
apanecatl
Senior Contributor II
Try uninstalling the driver, reinstalling it as administrator (right click > run as administrator), that should do the trick, you shouldn't need to use the device manager
apanecatl
