I suddenly cannot start J-Link debug. I checked the J-link ok @FRDM-K22F board.
Log info:
SEGGER J-Link GDB Server V4.98d - Terminal output channel
Connection closed by the GDB server.
Exception condition detected on fd 0
Quit (expect signal SIGINT when the program is resumed)
error detected on stdin
SEGGER J-Link GDB Server V4.98d Command Line Version
JLinkARM.dll V4.98d (DLL compiled Apr 28 2015 13:58:23)
-----GDB Server start settings-----
GDBInit file: none
GDB Server Listening port: 2331
SWO raw output listening port: 2332
Terminal I/O port: 2333
Accept remote connection: localhost only
Generate logfile: off
Verify download: on
Init regs on start: on
Silent mode: off
Single run mode: on
Target connection timeout: 0 ms
------J-Link related settings------
J-Link Host interface: USB
J-Link script: none
J-Link settings file: none
------Target related settings------
Target device: MK22FN512xxx12
Target interface: JTAG
Target interface speed: 30kHz
Target endian: little
Connecting to J-Link...
J-Link is connected.
Firmware: J-Link V9 compiled Apr 21 2015 18:10:40
Hardware: V9.30
S/N: 59300951
Feature(s): GDB
Checking target voltage...
Target voltage: 3.40 V
Listening on TCP/IP port 2331
Connecting to target...ERROR: Could not connect to target.
Target connection failed. GDBServer will be closed...Restoring target state and closing J-Link connection...
Shutting down...
Please check power, connection and settings.
please suggest how to solve this issue.
thanks,
JQ
已解决! 转到解答。
What is the GDB log saying?
Altough the messages are different, it could be that you have breakpoints on non-existing location set (this is a know GDB problem). Try clearing all breakpoints/watchpoints (see Failed to Debug with GDB: Breakpoints or Expressions on non-existing Locations | MCU on Eclipse). I hope this helps.
thank you!
we found the hardware wire connection is wrong. The J-link Reset pin should be connected to MCU chip reset signal reset_b, instead of jtag-TRST.
One interest thing is why this worked for several days until it had problem (then cannot work anymore).
