Is there a good way to determine which Kinetis microcontrollers support high-speed USB?
1,330件の閲覧回数
nonrepeatedmeme
I tried using the product selector and it does allow one to choose "FS/HS" under the USB column, but the parts it narrows the list to are primarily full-speed only parts (even though they're in the table as "FS/HS"). I did find a couple of family pages:
ARM Cortex-M4 Cores|Kinetis K2x MCUs|Freescale
ARM Cortex-M4 Cores|Kinetis K6x MCUs|Freescale
These provide some nice text about there being some parts that support high-speed USB 2.0 and, if I select the FS/HS USB option, give me some parts that support high-speed USB 2.0, but it's far from clear that this is a complete list of parts with that support.
I tried a live chat and the support technician's answer was "You're right, there doesn't seem to be a way to narrow down to just the high-speed parts. Maybe you should enter a question in the forums". So, here I am.
Is there a list somewhere that indicates which active Kinetis parts support high-speed USB2.0 or are the few parts listed on the above mentioned product pages the total of the parts with high-speed USB2.0 support?
タグ(2)
1,218件の閲覧回数
Hui_Ma
The Freescale Solution Advisor is a web-based tool that features interactive application wizards and a dynamic product selector.
Please check below steps to select related Kinetis products:
Wish it helps.
best regards,
Ma Hui
1,219件の閲覧回数
Hui_Ma
Wish it helps.
best regards,
Ma Hui
1,218件の閲覧回数
nonrepeatedmeme
Thank you! That was exactly what I was after.
