Installing new plugin into Codewarrior 10.4?
ソリューションへジャンプ
3,252件の閲覧回数
anand-k
How to install plugin into codewarrior IDE?
I was trying to install eclox plugin into the IDE. http://download.gna.org/eclox/packages/eclox_0.8.0.zip, but couldn't!
can anyone help/suggest me on this?
How to use doxygen effectively with CW IDE?
Thanks in advance,
regards,
Anand K
2,109件の閲覧回数
Kan_Li
Would you please try to click Help->Install New Software, and select the zip file according to the following steps?
Hope that helps,
2 返答(返信)
2,109件の閲覧回数
BlackNight
about doxygen/eclox with CodeWarrior, have a look here:
5 Best Eclipse Plugins: #1 (Eclox with Doxygen, Graphviz and Mscgen)
I hope this helps.
2,109件の閲覧回数
Kan_Li
Hope that helps,
