KwikStik-based EzPort programmer - Sources of tutorial
funky
I am trying to use the EzPort programmer of the Kwikstik.
I found some good documentation with an example project:
AN4406, KwikStik-based EzPort programmer - Application Notes
But I have some problems to get it working. It "fails" every time.
Do you know if there are some sources of the example project?
Till now it's just a black box because there is only the image and no sources.
Or do you know an other example code about how tho use the EzPort?
Thanks.
Hui_Ma
Please check attached AN4406 software source code.
Wish it helps.
Hui_Ma
Please check attached EzPort module validation code, which is based on TWR-K40X256 board.
Wish it helps.
funky
thanks for the module validation code.
However the source code of the KwikStik Demo Program is not available? Is that right?
Thanks in advance.
Hui_Ma
Wish it helps.
funky
Thank you very much!
