Need info on how to initialize i2s in k70
deepakbhagat
We need help regarding the I2S initialization of K70 and initialization of SGTL5000 codec. All the clock (ie. Mclk, BitClk, FS) will be generated by K70 wrt 44.1khz sampling freq. We are also not going to use the oscilator on TWR-SGTL-AUDIO as we will not have it on our final circuit. So can you guide me what steps and register setting I need to follow so that I can successfully generate sound from the codec.
Kan_Li
The MQX 4.0 provides example for TWR-K70F120M with TWR-AUDIO-SGTL, after installing MQX 4.0, you may easily find the driver for SGTL5000 in the following folder:
Hope that helps,
Kan_Li
Hope that helps,
