Incorrectly configuring PTA0 bricked unit
3,017 次查看
ignisuti_
MCU: KW41z
During development, I've managed to incorrectly/accidentally configure PTA0 with zero values. This appears to have bricked my unit in such a way that I can no longer download code. Note: The code that is currently on there appears to continue to run.
It appears that PTA0 is used by the SWD and my incorrect configuration has this being configured as a Touch Select Input (TSI).
I have not been able to hold the MCU in reset and recover. What other methods should I try to once again debug the unit?
2,917 次查看
Robin_Shen
Hi Joseph,
Please refer the method described in 'Bricking and Recovering FRDM-KL25Z Boards: Reset, SWD Clock and Low Power'.
I have attached the 'P&E Recovery Utility' that you may need to download.
Robin
2,917 次查看
ignisuti_
That un-bricked the boards. Thanks!
2,918 次查看
Robin_Shen
Hi Joseph,
Robin
