I know ADC0_DM0 is the ADC Channel 0 Differential Input Negative and ADC0_DP0 is the ADC Channel 0 DifferentialInput Positive. However I could not find any demo about how to use. Could you give me some suggestion?
已解决! 转到解答。
We do not have an example that covers your needs, still, you can check this post and use it as a guide that might work on your side .
https://community.nxp.com/thread/497086
Estephania
