How to use the ADC Channel 0 Differential Input of KW36?
1,257 次查看
jictannu
I know ADC0_DM0 is the ADC Channel 0 Differential Input Negative and ADC0_DP0 is the ADC Channel 0 Differential
Input Positive. However I could not find any demo about how to use. Could you give me some suggestion?
标记 (1)
1,152 次查看
estephania_mart
We do not have an example that covers your needs, still, you can check this post and use it as a guide that might work on your side .
https://community.nxp.com/thread/497086
Estephania
1,153 次查看
estephania_mart
Estephania
