How to load code(binary code) into KL25 and make it run out of reset w/o debugger connection?
ソリューションへジャンプ
5,066件の閲覧回数
anand-k
How to load code(elf binary code) into KL25 and make it run out of reset w/o debugger connection?..openSDA or USB multilink will be used just to download code into controller.
3,905件の閲覧回数
rgd04c
Hi Anand,
Not sure if I understand correctly but have you used the OpenSDA Bootloader mode?. You can just drag and drop a binary once the KL25 is recognized as a Mass storege device in the computer, just like a thumb drive!
Please refer to page 6 of attached document.
regards,
Gonzalo
3,905件の閲覧回数
rgd04c
Hi Anand,
regards,
Gonzalo
