How to know if configure line as bit ldd or gpio ldd
1,098 次查看
haroldvogel
I am working with a MKL36Z256VLL4 chip.  I need to configure a line to send a reset signal to external device.  How do I know if I should configure the line as a BIT_LDD or GPIO_LDD or something else.  The pin is PTB8 on the chip.
标记 (1)
1,003 次查看
Hello Harold,
You can both of them. I think BitIO_LDD is simple .
About the detail  introduce about the components, please find from "General Info":
right lick the component ->  Help on component .
There also are Typical Usage.
Hope it helps
TIC
