How to determine/confirm Cortex-M CPU speed using Serial Wire Viewer !
1,879 次查看
robertboys
Hello
I devised an easy way to determine the CPU speed using ARM Serial Wire Viewer.
This works with any Kinetis or LPC Cortex-M3, M4 or M7.  Assume also Cortex-M23 or 33.  No Cortex-M0 (has no SWV)
I posted it here:  Application Note 297: Using Serial Wire Viewer to Confirm CPU Speed
This uses eval version of Keil MDK and any ULINK or a Segger J-Link.
Tanks
Bob  Boys
ARM
1,526 次查看
soledad
Hi Bob,
Thank you for your input :smileywink:
Soledad
