Help check the MK66FN2M0VLQ18 connect 16bit SDRAM
3,803 次查看
hansonhe
Help check the MK66FN2M0VLQ18 connect 16bit SDRAM, use SDRAM type is IS42S16800F,16bit data width.
3,521 次查看
jeremyzhou
Please referring to the reference design.
How to access SDRAM based on K65 SDRAM controller
Ping
3,521 次查看
hansonhe
Jeremy,
It is some different from K65 which use 32bit data width. Do you have 16bit data width design guide?
