Freedom current capacity
2,148 次查看
georgealbertagu
What is the maximum current that can run through a Freedom board without the board burning?
1,962 次查看
apanecatl
Senior Contributor II
Do you refer to the board itself as if an electrical current were to magically circulate through the board; to the maximum current provided by a specific pin in a component? your questions is too general, you need to re formulate your question and be more specific.
1,962 次查看
georgealbertagu
Regarding power supply input. I have a 12V source that I am planning on converting down to 5V, but I do not know the current supplied so I want to be sure I will not burn my board
1,962 次查看
apanecatl
The voltage regulator in the FRDM boards is NCP1117ST33T3G, its maximum rated output current is 1000mA; you can use that figure as a milestone.
