FREEMASTER: Remote Server Tutorial
For Remote Control means, that is needed two computers - Server Computer and User Computer, which will be in connection.
There are two types of connection, which can be used - HTTP or DCOM. There are two different ways how to set up the remote control in Windows.
I made the tutorial, which describes both types of Remote Control.
Ok - so, let´s start!
HTTP Settings
On the Server Computer side:
1. Plug the board to the Server Computer
2. Go to Remote Communication Server
3. Set HTTP connection and choose the right COM Port according the plugged board
If the plugged board is on e.g. COM23, it is possible to edit number of Port in Device Manager
On the User PC side:
1. Open FreeMASTER,  go to Project -> Options
2. Choose Plug-in Module: FreeMASTER CommPlugin for Remote Server (HTTP) and type the IP address of the server,
do not forget join to IP address :8080
3. And start communication by STOP button to successful connection
DCOM Settings
1. Plug board to the Server Computer
2. Launch DCOM in FreeMASTER Remote Server
Choose COM according plugged board or edit COM according to step 2 - Server Computer in HTTP Connection (up).
3. Setting permissions for the user, User PC.
Right click on Computer -> Manage.
In Computer Management click to Distributed COM Users.
In Distributed COM Users Properties add the user, User Computer.
After that, set the permissions in Component Services. In cmd type dcomcnfg.exe
In Component Services go to Computers -> My Computer -> DCOM Config -> MCB FreeMASTER Remote Server Application
Right click on MCB FreeMASTER Remote Server Application and go to Properties.
In Security Tab is possible to add the permissions.
There are 3 types of permissions.
First permission - Launch and Activation Permissions.
There are 4 permission options. Local Launch and Remote Launch means, that user, User Computer can launch e.g. FM Remote Server Application.
But for success communication is needed allowing Local Activation and Remote Activation.
Second permission - Access Permissions.
Click to Edit and Allow Local Access and Remote Access for the user.
Do not forget that if there is a change of permissions, specifically allowing, it is necessary for User to log out and log in.
On the User Computer side:
1. Open Freemaster, go to Project -> Options
2. Choose Plug-in Module: FreeMASTER CommPlugin for Remote Server (DCOM) and for filling Connect string is possible to use Configure.
Definitely, type the IP address of the server and ;Port Name.
3. And start communication by STOP button in FreeMASTER to successful connection
And now.. you can do anything :-)
评论
Hello
I am trying to run FreeMaster Remote Server [HTTP mode] on a Windows 7 PC with the UART set to COM1 (COM1 exist and can be used by other programs - no other programs are using it when this is attempted).
The error message at the FreeMaster client is
"Could not open the communication port (Error 0x848a1001: Specified communication port not found on the server.)!"
I interpret this to mean that the client couldn't open COM1 (at 9600Baud)
What could the reason be for this - as noted above, COM1 is otherwise working for other programs?
I have tried running mcbsrv as user and as administrator, with the same results.
Mark
Hi Mark!
It is strange. I done it on different computers and it works! If you change the name of the Port and it is "is use" > Yes, you want to continue.
And remember, you must have computers in the same network.
Iva
%3CLINGO-SUB%20id%3D%22lingo-sub-1104157%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFREEMASTER%EF%BC%9A%E8%BF%9C%E7%A8%8B%E6%9C%8D%E5%8A%A1%E5%99%A8%E6%95%99%E7%A8%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104157%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%AF%B9%E4%BA%8E%E8%BF%9C%E7%A8%8B%E6%8E%A7%E5%88%B6%E6%9D%A5%E8%AF%B4%EF%BC%8C%E6%84%8F%E5%91%B3%E7%9D%80%E9%9C%80%E8%A6%81%E4%B8%A4%E5%8F%B0%E8%AE%A1%E7%AE%97%E6%9C%BA%20-%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E8%AE%A1%E7%AE%97%E6%9C%BA%E5%92%8C%E7%94%A8%E6%88%B7%E8%AE%A1%E7%AE%97%E6%9C%BA%EF%BC%8C%E5%AE%83%E4%BB%AC%E5%B0%86%E7%9B%B8%E4%BA%92%E8%BF%9E%E6%8E%A5%E3%80%82%20%3C%2FP%3E%3CP%3E%E6%9C%89%E4%B8%A4%E7%A7%8D%E7%B1%BB%E5%9E%8B%E7%9A%84%E8%BF%9E%E6%8E%A5%E5%8F%AF%E4%BE%9B%E4%BD%BF%E7%94%A8%20-%20HTTP%20%E6%88%96%20DCOM%E3%80%82%E5%9C%A8%20Windows%20%E4%B8%AD%E8%AE%BE%E7%BD%AE%E8%BF%9C%E7%A8%8B%E6%8E%A7%E5%88%B6%E6%9C%89%E4%B8%A4%E7%A7%8D%E4%B8%8D%E5%90%8C%E7%9A%84%E6%96%B9%E6%B3%95%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%88%B6%E4%BD%9C%E4%BA%86%E6%95%99%E7%A8%8B%EF%BC%8C%E6%8F%8F%E8%BF%B0%E4%BA%86%E4%B8%A4%E7%A7%8D%E7%B1%BB%E5%9E%8B%E7%9A%84%E8%BF%9C%E7%A8%8B%E6%8E%A7%E5%88%B6%E3%80%82%3C%2FP%3E%3CP%3EOk%20-%20so%2C%20let%C2%B4s%20start!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3EHTTP%20%E8%AE%BE%E7%BD%AE%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E5%9C%A8%E6%9C%8D%E5%8A%A1%E5%99%A8%E8%AE%A1%E7%AE%97%E6%9C%BA%E7%AB%AF%EF%BC%9A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E1.%20%E5%B0%86%E5%BC%80%E5%8F%91%E6%9D%BF%E6%8F%92%E5%85%A5%E6%9C%8D%E5%8A%A1%E5%99%A8%E8%AE%A1%E7%AE%97%E6%9C%BA%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E2.%20%E5%89%8D%E5%BE%80%E8%BF%9C%E7%A8%8B%E9%80%9A%E4%BF%A1%E6%9C%8D%E5%8A%A1%E5%99%A8%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server20.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server20.png%22%20style%3D%22width%3A%20251px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48886iA2720D65623FF992%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server20.png%22%20alt%3D%22FM_Remote_Server20.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server20.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E3.%20%E8%AE%BE%E7%BD%AEHTTP%E8%BF%9E%E6%8E%A5%EF%BC%8C%E5%B9%B6%E6%A0%B9%E6%8D%AE%E6%89%80%E6%8F%92%E7%9A%84%E6%9D%BF%E5%AD%90%E9%80%89%E6%8B%A9%E6%AD%A3%E7%A1%AE%E7%9A%84COM%E7%AB%AF%E5%8F%A3%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server21.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server21.png%22%20style%3D%22width%3A%20675px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48955i0897C16216619803%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server21.png%22%20alt%3D%22FM_Remote_Server21.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server21.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E5%A6%82%E6%9E%9C%E6%8F%92%E5%85%A5%E7%9A%84%E7%94%B5%E8%B7%AF%E6%9D%BF%E5%A4%84%E4%BA%8ECOM23%EF%BC%8C%E5%8F%AF%E4%BB%A5%E5%9C%A8%E8%AE%BE%E5%A4%87%E7%AE%A1%E7%90%86%E5%99%A8%E4%B8%AD%E7%BC%96%E8%BE%91%E7%AB%AF%E5%8F%A3%E5%8F%B7%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server3.png%22%20style%3D%22width%3A%20864px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48954iE6729346D7DF2317%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server3.png%22%20alt%3D%22FM_Remote_Server3.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server3.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server4.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server4.png%22%20style%3D%22width%3A%20422px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F19246i64B73C06F604648E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server4.png%22%20alt%3D%22FM_Remote_Server4.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server4.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server5.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server5.png%22%20style%3D%22width%3A%20647px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48952iEAEE96260779BC0A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server5.png%22%20alt%3D%22FM_Remote_Server5.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server5.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E5%9C%A8%E7%94%A8%E6%88%B7PC%E7%AB%AF%EF%BC%9A%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E1.%20%E6%89%93%E5%BC%80%20FreeMASTER%EF%BC%8C%E8%BD%AC%E5%88%B0%E2%80%9C%E9%A1%B9%E7%9B%AE%E2%80%9D-%26gt%3B%E2%80%9C%E9%80%89%E9%A1%B9%E2%80%9D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server15.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server15.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48951i65AEEF29EECF9F38%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server15.png%22%20alt%3D%22FM_Remote_Server15.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server15.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E2.%20%E9%80%89%E6%8B%A9%E6%8F%92%E4%BB%B6%E6%A8%A1%E5%9D%97%EF%BC%9AFreeMASTER%20CommPlugin%20for%20Remote%20Server%20(HTTP)%20%E5%B9%B6%E8%BE%93%E5%85%A5%E6%9C%8D%E5%8A%A1%E5%99%A8%E7%9A%84%20IP%20%E5%9C%B0%E5%9D%80%EF%BC%8C%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E4%B8%8D%E8%A6%81%E5%BF%98%E8%AE%B0%E5%8A%A0%E5%85%A5%20IP%20%E5%9C%B0%E5%9D%80%EF%BC%9A8080%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server18.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server18.png%22%20style%3D%22width%3A%20489px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48950i90DF919CEBF32127%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server18.png%22%20alt%3D%22FM_Remote_Server18.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server18.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E3.%E5%B9%B6%E6%8C%89STOP%E9%94%AE%E5%BC%80%E5%A7%8B%E9%80%9A%E8%AE%AF%EF%BC%8C%E7%9B%B4%E8%87%B3%E8%BF%9E%E6%8E%A5%E6%88%90%E5%8A%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server19.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server19.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48949i857B28DF485B206B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server19.png%22%20alt%3D%22FM_Remote_Server19.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server19.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3EDCOM%20%E8%AE%BE%E7%BD%AE%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E5%9C%A8%E6%9C%8D%E5%8A%A1%E5%99%A8%E8%AE%A1%E7%AE%97%E6%9C%BA%E7%AB%AF%EF%BC%9A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E1.%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E5%B0%86%E6%8F%92%E6%9D%BF%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%9C%8D%E5%8A%A1%E5%99%A8%E8%AE%A1%E7%AE%97%E6%9C%BA%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E2.%20%E5%9C%A8%20FreeMASTER%20%E8%BF%9C%E7%A8%8B%E6%9C%8D%E5%8A%A1%E5%99%A8%E4%B8%AD%E5%90%AF%E5%8A%A8%20DCOM%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server.png%22%20style%3D%22width%3A%20482px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48948i9644A9C3B9E7E53D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server.png%22%20alt%3D%22FM_Remote_Server.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E6%A0%B9%E6%8D%AE%E6%89%80%E6%8F%92%E7%9A%84%E6%9D%BF%E5%AD%90%E9%80%89%E6%8B%A9COM%E6%88%96%E8%80%85%E6%8C%89%E7%85%A7HTTP%E8%BF%9E%E6%8E%A5%EF%BC%88%E4%B8%8A%EF%BC%89%E4%B8%AD%E7%9A%84%E6%AD%A5%E9%AA%A42-%E6%9C%8D%E5%8A%A1%E5%99%A8%E8%AE%A1%E7%AE%97%E6%9C%BA%E7%BC%96%E8%BE%91COM%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server2.png%22%20style%3D%22width%3A%20409px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48946i84D406E5988CBA40%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server2.png%22%20alt%3D%22FM_Remote_Server2.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E3.%E4%B8%BA%E7%94%A8%E6%88%B7%E3%80%81%E7%94%A8%E6%88%B7PC%E8%AE%BE%E7%BD%AE%E6%9D%83%E9%99%90%E3%80%82%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E5%8F%B3%E9%94%AE%E5%8D%95%E5%87%BB%E8%AE%A1%E7%AE%97%E6%9C%BA-%26gt%3B%E7%AE%A1%E7%90%86%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E5%9C%A8%E8%AE%A1%E7%AE%97%E6%9C%BA%E7%AE%A1%E7%90%86%E4%B8%AD%E5%8D%95%E5%87%BB%E5%88%86%E5%B8%83%E5%BC%8F%20COM%20%E7%94%A8%E6%88%B7%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server7.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server7.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48945i277604BA02E0826B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server7.png%22%20alt%3D%22FM_Remote_Server7.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server7.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E5%9C%A8%E5%88%86%E5%B8%83%E5%BC%8F%20COM%20%E7%94%A8%E6%88%B7%E5%B1%9E%E6%80%A7%E4%B8%AD%E6%B7%BB%E5%8A%A0%E7%94%A8%E6%88%B7%E3%80%81%E7%94%A8%E6%88%B7%E8%AE%A1%E7%AE%97%E6%9C%BA%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server8_.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server8_.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48944iEFA20DF907484D49%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server8_.png%22%20alt%3D%22FM_Remote_Server8_.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server8_.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E4%B9%8B%E5%90%8E%EF%BC%8C%E5%9C%A8%E7%BB%84%E4%BB%B6%E6%9C%8D%E5%8A%A1%E4%B8%AD%E8%AE%BE%E7%BD%AE%E6%9D%83%E9%99%90%E3%80%82%E5%9C%A8cmd%E4%B8%AD%E8%BE%93%E5%85%A5dcomcnfg.exe%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E5%9C%A8%E7%BB%84%E4%BB%B6%E6%9C%8D%E5%8A%A1%E4%B8%AD%EF%BC%8C%E8%BD%AC%E5%88%B0%E8%AE%A1%E7%AE%97%E6%9C%BA-%26gt%3B%E6%88%91%E7%9A%84%E7%94%B5%E8%84%91-%26gt%3BDCOM%E9%85%8D%E7%BD%AE-%26gt%3BMCB%20FreeMASTER%20%E8%BF%9C%E7%A8%8B%E6%9C%8D%E5%8A%A1%E5%99%A8%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server9.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server9.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48943i397D9B04C4CF02C5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server9.png%22%20alt%3D%22FM_Remote_Server9.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server9.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E5%8F%B3%E9%94%AE%E5%8D%95%E5%87%BB%20MCB%20FreeMASTER%20%E8%BF%9C%E7%A8%8B%E6%9C%8D%E5%8A%A1%E5%99%A8%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%B9%B6%E8%BD%AC%E5%88%B0%E2%80%9C%E5%B1%9E%E6%80%A7%E2%80%9D%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server10.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server10.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48942i452C08D30164400A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server10.png%22%20alt%3D%22FM_Remote_Server10.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server10.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E5%9C%A8%E2%80%9C%E5%AE%89%E5%85%A8%E2%80%9D%E9%80%89%E9%A1%B9%E5%8D%A1%E4%B8%AD%E5%8F%AF%E4%BB%A5%E6%B7%BB%E5%8A%A0%E6%9D%83%E9%99%90%E3%80%82%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E6%9D%83%E9%99%90%E6%9C%89%203%20%E7%A7%8D%E7%B1%BB%E5%9E%8B%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server11.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server11.png%22%20style%3D%22width%3A%20414px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48941i7522188249FBDBE5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server11.png%22%20alt%3D%22FM_Remote_Server11.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server11.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E7%AC%AC%E4%B8%80%E4%B8%AA%E6%9D%83%E9%99%90%E2%80%94%E2%80%94%E5%90%AF%E5%8A%A8%E5%92%8C%E6%BF%80%E6%B4%BB%E6%9D%83%E9%99%90%E3%80%82%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E6%9C%89%204%20%E4%B8%AA%E6%9D%83%E9%99%90%E9%80%89%E9%A1%B9%E3%80%82%E6%9C%AC%E5%9C%B0%E5%90%AF%E5%8A%A8%E5%92%8C%E8%BF%9C%E7%A8%8B%E5%90%AF%E5%8A%A8%E6%84%8F%E5%91%B3%E7%9D%80%E7%94%A8%E6%88%B7%E3%80%81%E7%94%A8%E6%88%B7%E8%AE%A1%E7%AE%97%E6%9C%BA%E5%8F%AF%E4%BB%A5%E5%90%AF%E5%8A%A8%E4%BE%8B%E5%A6%82FM%20%E8%BF%9C%E7%A8%8B%E6%9C%8D%E5%8A%A1%E5%99%A8%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E4%BD%86%E4%B8%BA%E4%BA%86%E6%88%90%E5%8A%9F%EF%BC%8C%E9%9C%80%E8%A6%81%E5%85%81%E8%AE%B8%E6%9C%AC%E5%9C%B0%E6%BF%80%E6%B4%BB%E5%92%8C%E8%BF%9C%E7%A8%8B%E6%BF%80%E6%B4%BB%E7%9A%84%E9%80%9A%E4%BF%A1%E3%80%82%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server12.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server12.png%22%20style%3D%22width%3A%20377px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48940i04CAA3AD17A7B8A5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server12.png%22%20alt%3D%22FM_Remote_Server12.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server12.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E7%AC%AC%E4%BA%8C%E4%B8%AA%E6%9D%83%E9%99%90%E2%80%94%E2%80%94%E8%AE%BF%E9%97%AE%E6%9D%83%E9%99%90%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E5%8D%95%E5%87%BB%E2%80%9C%E7%BC%96%E8%BE%91%E2%80%9D%E5%B9%B6%E5%85%81%E8%AE%B8%E7%94%A8%E6%88%B7%E6%9C%AC%E5%9C%B0%E8%AE%BF%E9%97%AE%E5%92%8C%E8%BF%9C%E7%A8%8B%E8%AE%BF%E9%97%AE%E3%80%82%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server14.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server14.png%22%20style%3D%22width%3A%20377px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48939i3EA79DAB9B8C1FA7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server14.png%22%20alt%3D%22FM_Remote_Server14.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server14.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E4%B8%8D%E8%A6%81%E5%BF%98%E8%AE%B0%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%9D%83%E9%99%90%E5%8F%91%E7%94%9F%E5%8F%98%E5%8C%96%EF%BC%8C%E7%89%B9%E5%88%AB%E6%98%AF%E5%85%81%E8%AE%B8%EF%BC%8C%E5%88%99%E7%94%A8%E6%88%B7%E5%BF%85%E9%A1%BB%E6%B3%A8%E9%94%80%E5%B9%B6%E7%99%BB%E5%BD%95%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E5%9C%A8%E7%94%A8%E6%88%B7%E8%AE%A1%E7%AE%97%E6%9C%BA%E7%AB%AF%EF%BC%9A%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E1.%20%E6%89%93%E5%BC%80%20Freemaster%EF%BC%8C%E8%BF%9B%E5%85%A5%20Project%20-%26gt%3B%20Options%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E2.%20%E9%80%89%E6%8B%A9%E6%8F%92%E4%BB%B6%E6%A8%A1%E5%9D%97%EF%BC%9A%E7%94%A8%E4%BA%8E%E8%BF%9C%E7%A8%8B%E6%9C%8D%E5%8A%A1%E5%99%A8%EF%BC%88DCOM%EF%BC%89%E7%9A%84%20FreeMASTER%20CommPlugin%EF%BC%8C%E5%B9%B6%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E9%85%8D%E7%BD%AE%E6%9D%A5%E5%A1%AB%E5%85%85%E8%BF%9E%E6%8E%A5%E5%AD%97%E7%AC%A6%E4%B8%B2%E3%80%82%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E5%BD%93%E7%84%B6%EF%BC%8C%E8%BE%93%E5%85%A5%E6%9C%8D%E5%8A%A1%E5%99%A8%E7%9A%84IP%E5%9C%B0%E5%9D%80%E5%92%8C%E7%AB%AF%E5%8F%A3%E5%90%8D%E7%A7%B0%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server16.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server16.png%22%20style%3D%22width%3A%20489px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48938i8888A027F2E9A03B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server16.png%22%20alt%3D%22FM_Remote_Server16.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server16.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E3.%20%E9%80%9A%E8%BF%87%20FreeMASTER%20%E4%B8%AD%E7%9A%84%20STOP%20%E6%8C%89%E9%92%AE%E5%BC%80%E5%A7%8B%E9%80%9A%E4%BF%A1%EF%BC%8C%E7%9B%B4%E8%87%B3%E8%BF%9E%E6%8E%A5%E6%88%90%E5%8A%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E7%8E%B0%E5%9C%A8...%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%81%9A%E4%BB%BB%E4%BD%95%E4%BA%8B%E6%83%85%3A-)%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1104157%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EFreedom%E5%BC%80%E5%8F%91%E5%B9%B3%E5%8F%B0%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EKinetis%20E%E7%B3%BB%E5%88%97MCU%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EKinetis%20EA%E7%B3%BB%E5%88%97MCU%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EKinetis%E7%A1%AC%E4%BB%B6%E6%94%AF%E6%8C%81%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EKinetis%20K%E7%B3%BB%E5%88%97MCU%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EKinetis%20L%E7%B3%BB%E5%88%97MCU%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EKinetis%20V%E7%B3%BB%E5%88%97MCU%2F%E5%8D%95%E7%89%87%E6%9C%BA%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EKinetis%20W%E7%B3%BB%E5%88%97MCU%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EUSB%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104159%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFREEMASTER%EF%BC%9A%E8%BF%9C%E7%A8%8B%E6%9C%8D%E5%8A%A1%E5%99%A8%E6%95%99%E7%A8%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104159%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8C%E9%A9%AC%E5%85%8B%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E5%BE%88%E5%A5%87%E6%80%AA%E3%80%82%E6%88%91%E5%9C%A8%E4%B8%8D%E5%90%8C%E7%9A%84%E8%AE%A1%E7%AE%97%E6%9C%BA%E4%B8%8A%E5%AE%8C%E6%88%90%E4%BA%86%E8%BF%99%E4%B8%AA%E6%93%8D%E4%BD%9C%E5%B9%B6%E4%B8%94%E6%88%90%E5%8A%9F%E4%BA%86%EF%BC%81%E5%A6%82%E6%9E%9C%E6%82%A8%E6%9B%B4%E6%94%B9%E7%AB%AF%E5%8F%A3%E7%9A%84%E5%90%8D%E7%A7%B0%E5%B9%B6%E4%B8%94%E5%AE%83%E6%98%AF%E2%80%9C%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E2%80%9D%26gt%3B%E6%98%AF%EF%BC%8C%E5%88%99%E6%82%A8%E8%A6%81%E7%BB%A7%E7%BB%AD%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E8%AE%B0%E4%BD%8F%EF%BC%8C%E6%82%A8%E7%9A%84%E8%AE%A1%E7%AE%97%E6%9C%BA%E5%BF%85%E9%A1%BB%E4%BD%8D%E4%BA%8E%E5%90%8C%E4%B8%80%E7%BD%91%E7%BB%9C%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIva%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104158%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFREEMASTER%EF%BC%9A%E8%BF%9C%E7%A8%8B%E6%9C%8D%E5%8A%A1%E5%99%A8%E6%95%99%E7%A8%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104158%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E5%9C%A8%20Windows%207%20PC%20%E4%B8%8A%E8%BF%90%E8%A1%8C%20FreeMaster%20%E8%BF%9C%E7%A8%8B%E6%9C%8D%E5%8A%A1%E5%99%A8%20%5BHTTP%20%E6%A8%A1%E5%BC%8F%5D%EF%BC%8C%E5%B9%B6%E5%B0%86%20UART%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%20COM1%EF%BC%88COM1%20%E5%AD%98%E5%9C%A8%E5%B9%B6%E4%B8%94%E5%8F%AF%E4%BB%A5%E8%A2%AB%E5%85%B6%E4%BB%96%E7%A8%8B%E5%BA%8F%E4%BD%BF%E7%94%A8%20-%20%E5%B0%9D%E8%AF%95%E6%AD%A4%E6%93%8D%E4%BD%9C%E6%97%B6%E6%B2%A1%E6%9C%89%E5%85%B6%E4%BB%96%E7%A8%8B%E5%BA%8F%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%AE%83%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3EFreeMaster%20%E5%AE%A2%E6%88%B7%E7%AB%AF%E7%9A%84%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%E6%98%AF%3C%2FP%3E%3CP%3E%E2%80%9C%3CSTRONG%3E%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%E9%80%9A%E4%BF%A1%E7%AB%AF%E5%8F%A3%EF%BC%88%E9%94%99%E8%AF%AF%200x848a1001%EF%BC%9A%E5%9C%A8%E6%9C%8D%E5%8A%A1%E5%99%A8%E4%B8%8A%E6%9C%AA%E6%89%BE%E5%88%B0%E6%8C%87%E5%AE%9A%E7%9A%84%E9%80%9A%E4%BF%A1%E7%AB%AF%E5%8F%A3%E3%80%82%EF%BC%89%EF%BC%81%3C%2FSTRONG%3E%20%E2%80%9D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%86%E5%85%B6%E8%A7%A3%E9%87%8A%E4%B8%BA%E5%AE%A2%E6%88%B7%E7%AB%AF%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%20COM1%EF%BC%889600Baud%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E5%8F%AF%E8%83%BD%E6%98%AF%E4%BB%80%E4%B9%88%E5%8E%9F%E5%9B%A0%E9%80%A0%E6%88%90%E7%9A%84%20-%20%E5%A6%82%E4%B8%8A%E6%89%80%E8%BF%B0%EF%BC%8CCOM1%20%E6%AD%A3%E5%9C%A8%E4%B8%BA%E5%85%B6%E4%BB%96%E7%A8%8B%E5%BA%8F%E5%B7%A5%E4%BD%9C%EF%BC%9F%3C%2FP%3E%3CP%3E%3CEM%3E%E6%88%91%E5%B0%9D%E8%AF%95%E4%BB%A5%E7%94%A8%E6%88%B7%E5%92%8C%E7%AE%A1%E7%90%86%E5%91%98%E8%BA%AB%E4%BB%BD%E8%BF%90%E8%A1%8C%20mcbsrv%EF%BC%8C%E7%BB%93%E6%9E%9C%E7%9B%B8%E5%90%8C%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMark%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎01-06-2015 08:47 AM
更新人:
