FREEMASTER: Remote Server Tutorial
For Remote Control means, that is needed two computers - Server Computer and User Computer, which will be in connection.
There are two types of connection, which can be used - HTTP or DCOM. There are two different ways how to set up the remote control in Windows.
I made the tutorial, which describes both types of Remote Control.
Ok - so, let´s start!
HTTP Settings
On the Server Computer side:
1. Plug the board to the Server Computer
2. Go to Remote Communication Server
3. Set HTTP connection and choose the right COM Port according the plugged board
If the plugged board is on e.g. COM23, it is possible to edit number of Port in Device Manager
On the User PC side:
1. Open FreeMASTER,  go to Project -> Options
2. Choose Plug-in Module: FreeMASTER CommPlugin for Remote Server (HTTP) and type the IP address of the server,
do not forget join to IP address :8080
3. And start communication by STOP button to successful connection
DCOM Settings
1. Plug board to the Server Computer
2. Launch DCOM in FreeMASTER Remote Server
Choose COM according plugged board or edit COM according to step 2 - Server Computer in HTTP Connection (up).
3. Setting permissions for the user, User PC.
Right click on Computer -> Manage.
In Computer Management click to Distributed COM Users.
In Distributed COM Users Properties add the user, User Computer.
After that, set the permissions in Component Services. In cmd type dcomcnfg.exe
In Component Services go to Computers -> My Computer -> DCOM Config -> MCB FreeMASTER Remote Server Application
Right click on MCB FreeMASTER Remote Server Application and go to Properties.
In Security Tab is possible to add the permissions.
There are 3 types of permissions.
First permission - Launch and Activation Permissions.
There are 4 permission options. Local Launch and Remote Launch means, that user, User Computer can launch e.g. FM Remote Server Application.
But for success communication is needed allowing Local Activation and Remote Activation.
Second permission - Access Permissions.
Click to Edit and Allow Local Access and Remote Access for the user.
Do not forget that if there is a change of permissions, specifically allowing, it is necessary for User to log out and log in.
On the User Computer side:
1. Open Freemaster, go to Project -> Options
2. Choose Plug-in Module: FreeMASTER CommPlugin for Remote Server (DCOM) and for filling Connect string is possible to use Configure.
Definitely, type the IP address of the server and ;Port Name.
3. And start communication by STOP button in FreeMASTER to successful connection
And now.. you can do anything :-)
コメント
Hello
I am trying to run FreeMaster Remote Server [HTTP mode] on a Windows 7 PC with the UART set to COM1 (COM1 exist and can be used by other programs - no other programs are using it when this is attempted).
The error message at the FreeMaster client is
"Could not open the communication port (Error 0x848a1001: Specified communication port not found on the server.)!"
I interpret this to mean that the client couldn't open COM1 (at 9600Baud)
What could the reason be for this - as noted above, COM1 is otherwise working for other programs?
I have tried running mcbsrv as user and as administrator, with the same results.
Mark
Hi Mark!
It is strange. I done it on different computers and it works! If you change the name of the Port and it is "is use" > Yes, you want to continue.
And remember, you must have computers in the same network.
Iva
%3CLINGO-SUB%20id%3D%22lingo-sub-1104157%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFREEMASTER%3A%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%83%81%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104157%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%A8%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AE2%E5%8F%B0%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3E%E6%8E%A5%E7%B6%9A%E3%81%AB%E3%81%AF%E3%80%81HTTP%20%E3%81%A8%20DCOM%20%E3%81%AE%202%20%E3%81%A4%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%97%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82Windows%E3%81%A7%E3%83%AA%E3%83%A2%E3%82%B3%E3%83%B3%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%812%E3%81%A4%E3%81%AE%E7%95%B0%E3%81%AA%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E4%B8%A1%E6%96%B9%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AE%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%99%E3%82%8B%E3%83%81%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%92%E4%BD%9C%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EOk%20-%20so%2C%20let%C2%B4s%20start!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3EHTTP%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E5%81%B4%E3%81%A7%E3%80%81%E6%AC%A1%E3%81%AE%E6%93%8D%E4%BD%9C%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E1.%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E2.%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E9%80%9A%E4%BF%A1%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server20.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server20.png%22%20style%3D%22width%3A%20251px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48886iA2720D65623FF992%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server20.png%22%20alt%3D%22FM_Remote_Server20.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server20.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E3.%20HTTP%E6%8E%A5%E7%B6%9A%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%9F%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E9%81%A9%E5%88%87%E3%81%AACOM%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server21.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server21.png%22%20style%3D%22width%3A%20675px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48955i0897C16216619803%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server21.png%22%20alt%3D%22FM_Remote_Server21.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server21.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E3%83%97%E3%83%A9%E3%82%B0%E3%81%95%E3%82%8C%E3%81%9F%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E3%82%AA%E3%83%B3%E3%81%AE%E5%A0%B4%E5%90%88(%E4%BE%8B%3ACOM23%E3%81%A7%E3%81%AF%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%81%A7%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E6%95%B0%E3%82%92%E7%B7%A8%E9%9B%86%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server3.png%22%20style%3D%22width%3A%20864px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48954iE6729346D7DF2317%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server3.png%22%20alt%3D%22FM_Remote_Server3.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server3.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server4.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server4.png%22%20style%3D%22width%3A%20422px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F19246i64B73C06F604648E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server4.png%22%20alt%3D%22FM_Remote_Server4.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server4.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server5.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server5.png%22%20style%3D%22width%3A%20647px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48952iEAEE96260779BC0A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server5.png%22%20alt%3D%22FM_Remote_Server5.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server5.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BCPC%E5%81%B4%E3%81%AE%E5%A0%B4%E5%90%88%3A%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E1.%20FreeMASTER%E3%82%92%E9%96%8B%E3%81%8D%E3%80%81%5B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%5D-%5B%26gt%3B%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%5D%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server15.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server15.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48951i65AEEF29EECF9F38%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server15.png%22%20alt%3D%22FM_Remote_Server15.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server15.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E2.%20%E3%80%8CPlug-in%20Module%3A%20FreeMASTER%20CommPlugin%20for%20Remote%20Server%20(HTTP)%E3%80%8D%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%80%81%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AEIP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3EIP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A8080%E3%81%B8%E3%81%AE%E5%8F%82%E5%8A%A0%E3%82%92%E5%BF%98%E3%82%8C%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server18.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server18.png%22%20style%3D%22width%3A%20489px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48950i90DF919CEBF32127%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server18.png%22%20alt%3D%22FM_Remote_Server18.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server18.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E3.%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81STOP%E3%83%9C%E3%82%BF%E3%83%B3%E3%81%A7%E9%80%9A%E4%BF%A1%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%80%81%E6%8E%A5%E7%B6%9A%E3%81%AB%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server19.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server19.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48949i857B28DF485B206B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server19.png%22%20alt%3D%22FM_Remote_Server19.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server19.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3EDCOM%20%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E5%81%B4%E3%81%A7%E3%80%81%E6%AC%A1%E3%81%AE%E6%93%8D%E4%BD%9C%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E1.%20%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E2.%20FreeMASTER%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%A7DCOM%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server.png%22%20style%3D%22width%3A%20482px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48948i9644A9C3B9E7E53D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server.png%22%20alt%3D%22FM_Remote_Server.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%9F%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6COM%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81%E6%89%8B%E9%A0%862%20-%20HTTP%E6%8E%A5%E7%B6%9A(%E4%B8%8A)%E3%81%AE%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6COM%E3%82%92%E7%B7%A8%E9%9B%86%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server2.png%22%20style%3D%22width%3A%20409px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48946i84D406E5988CBA40%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server2.png%22%20alt%3D%22FM_Remote_Server2.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E3.%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BCPC%E3%81%AE%E6%A8%A9%E9%99%90%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%5B%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%5D%20-%20%5B%E7%AE%A1%E7%90%86%5D%20%26gt%3B%E3%82%92%E5%8F%B3%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%5B%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%81%AE%E7%AE%A1%E7%90%86%5D%E3%81%A7%E3%80%81%5B%E5%88%86%E6%95%A3COM%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%5D%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server7.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server7.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48945i277604BA02E0826B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server7.png%22%20alt%3D%22FM_Remote_Server7.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server7.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%5B%E5%88%86%E6%95%A3%20COM%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AE%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%5D%20%E3%81%A7%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%20%5B%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%20%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%5D%20%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server8_.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server8_.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48944iEFA20DF907484D49%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server8_.png%22%20alt%3D%22FM_Remote_Server8_.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server8_.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%81%A7%E6%A8%A9%E9%99%90%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82cmd%E3%81%A7dcomcnfg.exe%E3%81%A8%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%5B%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%20%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%5D%20%E3%81%A7%E3%80%81%5B%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%5D%20%26gt%3B%20%5B%E3%83%9E%E3%82%A4%20%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%5D%20-%26gt%3B%20%5BDCOM%20%E6%A7%8B%E6%88%90%5D%20-%26gt%3B%20%5BMCB%20FreeMASTER%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%5D%20%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server9.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server9.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48943i397D9B04C4CF02C5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server9.png%22%20alt%3D%22FM_Remote_Server9.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server9.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3EMCB%20FreeMASTER%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%8F%B3%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%80%81%5B%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%5D%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server10.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server10.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48942i452C08D30164400A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server10.png%22%20alt%3D%22FM_Remote_Server10.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server10.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E3%82%BF%E3%83%96%E3%81%A7%E3%81%AF%E3%80%81%E6%A8%A9%E9%99%90%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E6%A8%A9%E9%99%90%E3%81%AB%E3%81%AF%203%20%E3%81%A4%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%97%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server11.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server11.png%22%20style%3D%22width%3A%20414px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48941i7522188249FBDBE5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server11.png%22%20alt%3D%22FM_Remote_Server11.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server11.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E6%9C%80%E5%88%9D%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E8%A8%B1%E5%8F%AF%20-%20%E8%B5%B7%E5%8B%95%E3%81%A8%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E5%8C%96%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E8%A8%B1%E5%8F%AF%E3%80%82%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E4%E3%81%A4%E3%81%AE%E6%A8%A9%E9%99%90%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E8%B5%B7%E5%8B%95%E3%81%A8%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E8%B5%B7%E5%8B%95%E3%81%A8%E3%81%AF%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82FM%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%83%BB%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%83%BB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%82%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E6%88%90%E5%8A%9F%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%81%AF%E3%80%81%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%99%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A8%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%99%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E8%A8%B1%E5%8F%AF%E3%81%99%E3%82%8B%E9%80%9A%E4%BF%A1%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server12.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server12.png%22%20style%3D%22width%3A%20377px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48940i04CAA3AD17A7B8A5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server12.png%22%20alt%3D%22FM_Remote_Server12.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server12.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E2%20%E7%95%AA%E7%9B%AE%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E8%A8%B1%E5%8F%AF%20-%20%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E8%A8%B1%E5%8F%AF%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AE%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A8%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%82%92%E7%B7%A8%E9%9B%86%E3%81%8A%E3%82%88%E3%81%B3%E8%A8%B1%E5%8F%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server14.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server14.png%22%20style%3D%22width%3A%20377px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48939i3EA79DAB9B8C1FA7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server14.png%22%20alt%3D%22FM_Remote_Server14.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server14.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E6%A8%A9%E9%99%90%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E7%89%B9%E3%81%AB%E8%A8%B1%E5%8F%AF%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%8C%E3%83%AD%E3%82%B0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%A6%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E5%BF%98%E3%82%8C%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E5%81%B4%E3%81%A7%E3%80%81%E6%AC%A1%E3%81%AE%E6%93%8D%E4%BD%9C%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E1.%20Freemaster%E3%82%92%E9%96%8B%E3%81%8D%E3%80%81%5B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%5D-%5B%26gt%3B%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%5D%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E2.%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%3AFreeMASTER%20CommPlugin%20for%20Remote%20Server(DCOM)%E3%81%A8%E5%85%A5%E5%8A%9B%E7%94%A8%E3%81%AEConnect%E6%96%87%E5%AD%97%E5%88%97%E3%81%AF%E3%80%81Configure%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E3%82%82%E3%81%A1%E3%82%8D%E3%82%93%E3%80%81%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AEIP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%A8%3BP%20ort%E5%90%8D%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server16.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FM_Remote_Server16.png%22%20style%3D%22width%3A%20489px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48938i8888A027F2E9A03B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FM_Remote_Server16.png%22%20alt%3D%22FM_Remote_Server16.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFM_Remote_Server16.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E3.%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81FreeMASTER%E3%81%AESTOP%E3%83%9C%E3%82%BF%E3%83%B3%E3%81%A7%E9%80%9A%E4%BF%A1%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%80%81%E6%8E%A5%E7%B6%9A%E3%81%AB%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2014.0pt%3B%22%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E3%81%95%E3%81%A6%E3%80%82%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E4%BD%95%E3%81%A7%E3%82%82%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3A-)%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1104157%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EFreedom%E9%96%8B%E7%99%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EKinetis%20E%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%BB%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EKinetis%20EA%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BAMCU%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EKinetis%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%BB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EKinetis%20K%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BAMCU%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EKinetis%20L%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%BB%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EKinetis%20V%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%BB%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EKinetis%20W%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%83%BB%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EUSB%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104159%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AFREEMASTER%3A%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%83%81%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104159%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%9E%E3%83%BC%E3%82%AF!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%8D%E6%80%9D%E8%AD%B0%E3%81%A7%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E5%88%A5%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%A7%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E3%81%9D%E3%82%8C%E3%81%AF%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99!%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E5%90%8D%E5%89%8D%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E3%80%8Cis%20use%E3%80%8D%26gt%3B%E3%80%8CYes%E3%80%8D%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E7%B6%9A%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E5%90%8C%E3%81%98%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E5%86%85%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E5%BF%98%E3%82%8C%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIva%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1104158%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AFREEMASTER%3A%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%83%81%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104158%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFUART%E3%81%8CCOM1%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9FWindows%207%20PC%E3%81%A7FreeMaster%20Remote%20Server%20%5BHTTP%E3%83%A2%E3%83%BC%E3%83%89%5D%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99(COM1%E3%81%AF%E5%AD%98%E5%9C%A8%E3%81%97%E3%80%81%E4%BB%96%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99-%E3%81%93%E3%82%8C%E3%81%8C%E8%A9%A6%E3%81%BF%E3%82%89%E3%82%8C%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AB%E4%BB%96%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93)%E3%80%82%3C%2FP%3E%3CP%3EFreeMaster%20%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%A7%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%E3%80%8C%3CSTRONG%3E%E9%80%9A%E4%BF%A1%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E9%96%8B%E3%81%8F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F(%E3%82%A8%E3%83%A9%E3%83%BC%200x848a1001%3A%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%E9%80%9A%E4%BF%A1%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AB%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93)!%3C%2FSTRONG%3E%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%8CCOM1(9600Baud)%E3%82%92%E9%96%8B%E3%81%8F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%99%E3%82%8B%E3%81%A8%E8%A7%A3%E9%87%88%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E7%90%86%E7%94%B1%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%20-%20%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%80%81COM1%E3%81%AF%E4%BB%96%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%A7%E3%82%82%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3CEM%3E%E7%A7%81%E3%81%AF%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E7%AE%A1%E7%90%86%E8%80%85%E3%81%A8%E3%81%97%E3%81%A6mcbsrv%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%90%8C%E3%81%98%E7%B5%90%E6%9E%9C%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMark%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎01-06-2015 08:47 AM
更新者:
