FRDM KW36(BLE): Getting gHciRemoteUserTerminatedConnection_c as disconnection reason for every disconnection
4,327 次查看
pvelayu1
Whenever KW36 (BLE module) disconnects from the connected phone, the reason for disconnection in "gConnEvtDisconnected_c"is always gHciRemoteUserTerminatedConnection_c, But what I would like to know why NXP LE stack is not sending the reason "gHciPinOrKeyMissing_c" or any other disconnect reasons appropriately.?
Prakash V
标记 (3)
7 回复数
4,085 次查看
xing_chang
If you pull the device away, you will get the reason ‘gHciConnectionTimeout_c’ after disconnecting.
4,085 次查看
pvelayu1
Hi Xing Chang,
Is there any disconnect reason for link key miss?
Prakash V
4,085 次查看
xing_chang
Hi [email protected]‌,
When the KW36 loses the link key, the encryption will fail when reconnecting, but the kw36 will not be disconnected. The disconnection is initiated by the mobile phone.
4,085 次查看
stephanie_m
Do you have a sniffer log with the information you are mentioning ? How are you seeing this ? Also, which example are you using ? How are you configuring ? Are you using some mobile application ?
Estephania
4,085 次查看
pvelayu1
Hello estephania_martinez‌,
I am keeping breakpoint in the application event ""gConnEvtDisconnected_c"  during various disconnection scenarios but even at different disconnect scenarios, i could see always the reason as gHciRemoteUserTerminatedConnection_c.
I am using hid_device project, i am not configuring anything related to disconnect reason.
No i am not using any mobile application.
4,085 次查看
stephanie_m
Could you please share with me the sniffer log of the communication ? Also, have you tried using the temperature collector example ?
Estephania
4,085 次查看
pvelayu1
Hi Estephania,
I have attached the airtrace of the issue, where for every disconnection, gHciRemoteUserTerminatedConnection_c reason is received.
Prakash V
