FRDM KW36(BLE): Getting gHciRemoteUserTerminatedConnection_c as disconnection reason for every disconnection
4,373件の閲覧回数
pvelayu1
Whenever KW36 (BLE module) disconnects from the connected phone, the reason for disconnection in "gConnEvtDisconnected_c"is always gHciRemoteUserTerminatedConnection_c, But what I would like to know why NXP LE stack is not sending the reason "gHciPinOrKeyMissing_c" or any other disconnect reasons appropriately.?
Prakash V
タグ(3)
7 返答(返信)
4,131件の閲覧回数
xing_chang
If you pull the device away, you will get the reason ‘gHciConnectionTimeout_c’ after disconnecting.
4,131件の閲覧回数
pvelayu1
Hi Xing Chang,
Is there any disconnect reason for link key miss?
Prakash V
4,131件の閲覧回数
xing_chang
Hi [email protected]‌,
When the KW36 loses the link key, the encryption will fail when reconnecting, but the kw36 will not be disconnected. The disconnection is initiated by the mobile phone.
4,131件の閲覧回数
stephanie_m
Do you have a sniffer log with the information you are mentioning ? How are you seeing this ? Also, which example are you using ? How are you configuring ? Are you using some mobile application ?
Estephania
4,131件の閲覧回数
pvelayu1
Hello estephania_martinez‌,
I am keeping breakpoint in the application event ""gConnEvtDisconnected_c"  during various disconnection scenarios but even at different disconnect scenarios, i could see always the reason as gHciRemoteUserTerminatedConnection_c.
I am using hid_device project, i am not configuring anything related to disconnect reason.
No i am not using any mobile application.
4,131件の閲覧回数
stephanie_m
Could you please share with me the sniffer log of the communication ? Also, have you tried using the temperature collector example ?
Estephania
4,131件の閲覧回数
pvelayu1
Hi Estephania,
I have attached the airtrace of the issue, where for every disconnection, gHciRemoteUserTerminatedConnection_c reason is received.
Prakash V
