Ethernet Drivers for MK60512MD100
2,657 次查看
trilokjt
I'm trying to write code for sending packets and receive back t via Ethernet. Before I never worked on Ethernet please could any one provide me sample code for above controller
Thank you
标记 (2)
5 回复数
2,399 次查看
ivadorazinova
You can try these options.
Option 1: examples for FNET TCP/IP Stack
FNET Embedded TCP/IP Stack
all questions regarding FNET you can post here FNET - Embedded TCP/IP Stack download | SourceForge.net
Option 2: You can also check KSDK 1.3 with example for fsl_phy_driver,
HTTP Server Demo on lwIP TCP/IP Stack
Ping Demo on lwIP TCP/IP Stack
TCP Echo Demo on lwIP TCP/IP Stack
UDP Echo Demo lwIP TCP/IP Stackall questions regarding KSDK you can ask at Kinetis Software Development Kit​
I hope this helps you.
In case of any questions, please let me know.
Iva
2,399 次查看
trilokjt
I'm not able to found any example in https://community.freescale.com/external-link.jspa?url=http%3A%2F%2Ffnet.sourceforge.net%2F  ​where can i found example?
2,399 次查看
ivadorazinova
Hi Trilok,
you must download the stack.
Please, go to website FNET Embedded TCP/IP Stack and click to download.
after downloading, please install FNET then see User Manual for Getting Started.
I hope this helps.
Iva
2,399 次查看
trilokjt
I downloaded, but the thing is I wanted to learn about UDP in that he has given ALL PROTOCOLS(telenet,ping,tcp...etc) and that too in only flash. I can't able to run it in debug mode. Please can you tell me how to understand UDP protocol from that file I'm facing difficulty to understand.
Thank you
Trilok
2,399 次查看
trilokjt
Got the file
Thank you
