Erase Flash Action
Erase Flash Action
victorheca
 When I debug my firmware on MCU of  MKL25Z128 using PnE. It always failed and hang MCUXpress IDE software. IDE found PnE device and PnE works well under Code Warrior.  Is there anything wrong with my settings? Many thanks.
victorheca
Hi, Erich,
I managed to make the debugger works now. Thanks for your help.
victorheca
Hi, Erich,
  Here is my project. Many Thanks to your kind help.
ErichStyger
Specialist I
I noticed that in your project you have the wrong SDK/MCU assigned?
This can cause all kind of problems, so I suggest that you change the SDK to the KL25Z one.
victorheca
Sorry my debugger is PE Micro.
ErichStyger
Specialist I
Can you share your project?
