Diable GPIO in UART pins
2,162 次查看
boominperera
Does anyone know how I could disable the UART0 in pins (PTB1 and PTB2). I need to disable the UART0 entirely to go into LLS mode so that is very little current consumption.This is in the Frdm KL05Z board.
标记 (3)
2,089 次查看
mjbcswitzerland
Specialist V
Hi Boomin
If you add an internal pull-up to the UART Rx it should give you lowest power consumption (to avoid floating). Driving an output in LLS mode should not be an issue.
Mark
Kinetis: http://www.utasker.com/kinetis.html
KL05
- http://www.utasker.com/kinetis/FRDM-KL05Z.html (with LLS mode reference)
- LLS Video on FRDM-KL05Z https://www.youtube.com/watch?v=iZEMRiDmHzw&feature=youtu.be
2,089 次查看
boominperera
Hi Mark,
It works, Thank you
2,090 次查看
mjbcswitzerland
Specialist V
Hi Boomin
Mark
KL05
