DTM configuration for KW36
2,788 次查看
nsuresh2
Hi estephania_martinez‌,
I configured KW36 DTM as mentioned in the below link (Through a 2-wire UART interface)
Direct Test Mode (DTM) Configurations for the KW family
But to verify the DTM behavior I tested using the below commands
1. LE Reset
    (a)  0x0000
    (b)  0x0204
    (c)  0x0300
2. LE Transmitter Test
      0x8000
3. LE Receiver Test
      0x4000
4. LE Test End
      0xC000
In the above-mentioned commands, LE Reset is not getting passed with all the 3 commands and LE Test End command is also failed.
Can you please check this issue?
Hardware used: USB to TTL converter (3.3v logic level)
Thanks!
Naven Suresh
标记 (2)
4 回复数
540 次查看
Parshva_21
which firmware did you used?
541 次查看
Parshva_21
Did you tried it over development board or your own application?
2,654 次查看
stephanie_m
Are you using test tool? Could you please share with me the complete command you sent and the response ?
Estephania
2,654 次查看
nsuresh2
Thanks for the response.
It is not the test tool. It is a third-party tool and now it is working fine the issue was in address configuration.
Thanks!
Naven Suresh
%3CLINGO-SUB%20id%3D%22lingo-sub-993145%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EKW36%20%E7%9A%84%20DTM%20%E9%85%8D%E7%BD%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-993145%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Festephania_martinez%22%20target%3D%22_blank%22%3Eestephania_martinez%3C%2FA%3E%20%E2%80%8C%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%8C%89%E7%85%A7%E4%BB%A5%E4%B8%8B%E9%93%BE%E6%8E%A5%E4%B8%AD%E7%9A%84%E8%AF%B4%E6%98%8E%E9%85%8D%E7%BD%AE%E4%BA%86KW36%20DTM%EF%BC%88%3CSTRONG%3E%E9%80%9A%E8%BF%872%E7%BA%BFUART%E6%8E%A5%E5%8F%A3%3C%2FSTRONG%3E%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-341216%22%20target%3D%22_blank%22%3EKW%E7%B3%BB%E5%88%97%E7%9B%B4%E6%8E%A5%E6%B5%8B%E8%AF%95%E6%A8%A1%E5%BC%8F%EF%BC%88DTM%EF%BC%89%E9%85%8D%E7%BD%AE%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%BA%E4%BA%86%E9%AA%8C%E8%AF%81%20DTM%20%E7%9A%84%E8%A1%8C%E4%B8%BA%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%3CP%3E1.%20LE%20RESET%3C%2FP%3E%3CP%3E%EF%BC%88a%EF%BC%890x0000%3C%2FP%3E%3CP%3E%EF%BC%88b%EF%BC%890x0204%3C%2FP%3E%3CP%3E%EF%BC%88c%EF%BC%890x0300%3C%2FP%3E%3CP%3E2.%20%E4%BD%8E%E5%8A%9F%E8%80%97%E5%8F%91%E5%B0%84%E5%99%A8%E6%B5%8B%E8%AF%95%3C%2FP%3E%3CP%3E0x8000%3C%2FP%3E%3CP%3E3.%20LE%E6%8E%A5%E6%94%B6%E6%9C%BA%E6%B5%8B%E8%AF%95%3C%2FP%3E%3CP%3E0x4000%3C%2FP%3E%3CP%3E4.%20LE%20%E6%B5%8B%E8%AF%95%E7%BB%93%E6%9D%9F%3C%2FP%3E%3CP%3E0xC000%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E4%B8%8A%E8%BF%B0%E5%91%BD%E4%BB%A4%E4%B8%AD%EF%BC%8CLE%20Reset%20%E5%91%BD%E4%BB%A4%E5%9C%A8%E6%89%80%E6%9C%89%203%20%E4%B8%AA%E5%91%BD%E4%BB%A4%E4%B8%AD%E5%9D%87%E6%9C%AA%E9%80%9A%E8%BF%87%EF%BC%8CLE%20Test%20End%20%E5%91%BD%E4%BB%A4%E4%B9%9F%E5%A4%B1%E8%B4%A5%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E6%82%A8%E5%B8%AE%E5%BF%99%E6%9F%A5%E7%9C%8B%E4%B8%80%E4%B8%8B%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E4%BD%BF%E7%94%A8%E7%9A%84%E7%A1%AC%E4%BB%B6%EF%BC%9A%3C%2FSTRONG%3E%20USB%20%E8%BD%AC%20TTL%20%E5%8F%98%E6%B5%81%E5%99%A8%EF%BC%883.3V%20%E9%80%BB%E8%BE%91%E7%94%B5%E5%B9%B3%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E7%BA%B3%E6%96%87%C2%B7%E8%8B%8F%E9%9B%B7%E4%BB%80%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2384169%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20DTM%20configuration%20for%20KW36%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2384169%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E4%B8%AA%E5%9B%BA%E4%BB%B6%E7%89%88%E6%9C%AC%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2384168%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20DTM%20configuration%20for%20KW36%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2384168%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E6%98%AF%E5%9C%A8%E5%BC%80%E5%8F%91%E6%9D%BF%E4%B8%8A%E8%BF%98%E6%98%AF%E5%9C%A8%E6%82%A8%E8%87%AA%E5%B7%B1%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%E5%B0%9D%E8%AF%95%E8%BF%87%E7%9A%84%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-993147%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20DTM%20configuration%20for%20KW36%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-993147%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%AE%83%E4%B8%8D%E6%98%AF%E6%B5%8B%E8%AF%95%E5%B7%A5%E5%85%B7%E3%80%82%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E7%AC%AC%E4%B8%89%E6%96%B9%E5%B7%A5%E5%85%B7%EF%BC%8C%E7%8E%B0%E5%9C%A8%E8%BF%90%E8%A1%8C%E6%AD%A3%E5%B8%B8%EF%BC%8C%E9%97%AE%E9%A2%98%E5%87%BA%E5%9C%A8%E5%9C%B0%E5%9D%80%E9%85%8D%E7%BD%AE%E4%B8%8A%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E7%BA%B3%E6%96%87%C2%B7%E8%8B%8F%E9%9B%B7%E4%BB%80%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-993146%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20DTM%20configuration%20for%20KW36%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-993146%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%A0%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E6%B5%8B%E8%AF%95%E5%B7%A5%E5%85%B7%E5%90%97%EF%BC%9F%E8%AF%B7%E9%97%AE%E6%82%A8%E8%83%BD%E5%90%A6%E5%B0%86%E6%82%A8%E5%8F%91%E9%80%81%E7%9A%84%E5%AE%8C%E6%95%B4%E5%91%BD%E4%BB%A4%E5%92%8C%E5%93%8D%E5%BA%94%E5%88%86%E4%BA%AB%E7%BB%99%E6%88%91%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E5%9F%83%E6%96%AF%E7%89%B9%E6%B3%95%E5%B0%BC%E4%BA%9A%3C%2FP%3E%3C%2FLINGO-BODY%3E
