SIM Macro activation in MCUxpresso
516件の閲覧回数
ve3id
I'm picking up an old project that was originally built using KDE and later modified using mcuexpresso.
I downloaded the latest version of the IDE and created a new C/C++ project using SDK2.11.0 for the FRDM_K64F board which I have.
I'm copying code from the old project as it had all sorts of stuff I don't want anymore and am trying to build up in the new project from scratch.
The first code I pasted in was a port initialisation.
Problem is when I compile I get "undefined'' errors on all hardware references:
./source/Frere_2016.c:52:1: error: 'SIM_SCGC5' undeclared (first use in this function)
52 | SIM_SCGC5 |= SIM_SCGC5_PORTA_MASK; // Enable Port A Clock Gate C
I have unzipped the SDK with no difference.
It seems that the original source code must have had some assignment made which I am not copying, but surely that should be covered in a new project by the following:
#include <stdio.h>
#include "board.h"
#include "peripherals.h"
#include "pin_mux.h"
#include "clock_config.h"
#include "fsl_debug_console.h"
I even tried adding #include "MK64F12.h" to no avail
Any help really apprecaited!
Nigel
So I started
2 返答(返信)
460件の閲覧回数
Hello @ve3id
The compile error happens because SIM_SCGC5 is an old Kinetis register symbol; in MCUXpresso SDK 2.x for FRDM-K64F you should use SIM->SCGC5 and similarly convert the other hardware register references to PERIPHERAL->REGISTER syntax.
For you specific line, change
to
SIM->SCGC5 |= SIM_SCGC5_PORTA_MASK;
Thank you.
Alice
426件の閲覧回数
ve3id
Thank you very much, Alice.  You are so knowledgeable that you make it look easy!
Now I can get on with my project
cheers
Nigel
%3CLINGO-SUB%20id%3D%22lingo-sub-2387889%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMCUxpresso%E3%81%A7%E3%81%AESIM%E3%83%9E%E3%82%AF%E3%83%AD%E3%81%AE%E6%9C%89%E5%8A%B9%E5%8C%96%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2387889%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%80%81%E5%85%83%E3%80%85%E3%81%AFKDE%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E6%A7%8B%E7%AF%89%E3%81%95%E3%82%8C%E3%80%81%E5%BE%8C%E3%81%ABmcuexpresso%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E4%BF%AE%E6%AD%A3%E3%81%95%E3%82%8C%E3%81%9F%E5%8F%A4%E3%81%84%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E5%BC%95%E3%81%8D%E7%B6%99%E3%81%84%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%80%E6%96%B0%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AEIDE%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%80%81FRDM_K64F%E3%83%9C%E3%83%BC%E3%83%89%E7%94%A8%E3%81%AESDK2.11.0%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E6%96%B0%E3%81%97%E3%81%84C%2FC%2B%2B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E5%8F%A4%E3%81%84%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E3%81%AF%E3%82%82%E3%81%86%E5%BF%85%E8%A6%81%E3%81%AE%E3%81%AA%E3%81%84%E3%82%82%E3%81%AE%E3%81%8C%E3%81%9F%E3%81%8F%E3%81%95%E3%82%93%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E3%81%9D%E3%81%93%E3%81%8B%E3%82%89%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%A6%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%82%BC%E3%83%AD%E3%81%8B%E3%82%89%E6%A7%8B%E7%AF%89%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%80%E5%88%9D%E3%81%AB%E8%B2%BC%E3%82%8A%E4%BB%98%E3%81%91%E3%81%9F%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E6%99%82%E3%81%AB%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E5%8F%82%E7%85%A7%E3%81%A7%E3%80%8C%E6%9C%AA%E5%AE%9A%E7%BE%A9%E3%80%8D%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E.%2Fsource%2FFrere_2016.c%3A52%3A1%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20'SIM_SCGC5'%20%E3%81%8C%E5%AE%A3%E8%A8%80%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%20(%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%A7%E3%81%AE%E6%9C%80%E5%88%9D%E3%81%AE%E4%BD%BF%E7%94%A8)%3CBR%20%2F%3E%2052%20%7C%20SIM_SCGC5%20%7C%3D%20SIM_SCGC5_PORTA_MASK%3B%20%2F%2F%20%E3%83%9D%E3%83%BC%E3%83%88A%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B2%E3%83%BC%E3%83%88C%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3ESDK%E3%82%92%E8%A7%A3%E5%87%8D%E3%81%97%E3%81%A6%E3%82%82%E5%A4%89%E3%82%8F%E3%82%8A%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E5%85%83%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AF%E3%80%81%E7%A7%81%E3%81%8C%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%9F%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E6%96%B0%E3%81%97%E3%81%84%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%82%AB%E3%83%90%E3%83%BC%E3%81%95%E3%82%8C%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FP%3E%3CP%3E%23include%20%3CSTDIO.H%3E%3CBR%20%2F%3E%23include%20%22board.h%22%3CBR%20%2F%3E%23include%E3%80%8C%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%80%8D%3CBR%20%2F%3E%23include%20%22pin_mux.h%22%3CBR%20%2F%3E%23include%20%22clock_config.h%22%3CBR%20%2F%3E%23include%20%22fsl_debug_console.h%22%3C%2FSTDIO.H%3E%3C%2FP%3E%3CP%3E%23include%20%22MK64F12.h%22%20%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%8A%B9%E6%9E%9C%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A9%E3%82%93%E3%81%AA%E3%81%94%E6%94%AF%E6%8F%B4%E3%81%A7%E3%82%82%E5%A4%A7%E5%A4%89%E3%81%82%E3%82%8A%E3%81%8C%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%EF%BC%81%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%8A%E3%82%A4%E3%82%B8%E3%82%A7%E3%83%AB%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3ESO%E5%A7%8B%E3%82%81%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2388132%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SIM%20Macro%20activation%20in%20MCUxpresso%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2388132%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F460%22%20target%3D%22_blank%22%3E%40ve3id%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%B5%B7%E3%81%93%E3%82%8B%E7%90%86%E7%94%B1%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%80%9A%E3%82%8A%3C%2FSPAN%3E%E3%81%A7%E3%81%99%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3ESIM_SCGC5%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%E3%81%AF%E5%8F%A4%E3%81%84Kinetis%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E8%A8%98%E5%8F%B7%E3%81%A7%E3%81%99%E3%80%82FRDM-K64F%E7%94%A8%E3%81%AEMCUXpresso%20SDK%202.x%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%99%E3%81%B9%E3%81%8D%3C%2FSPAN%3E%E3%81%A7%E3%81%99%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3ESIM-%26gt%3BSCGC5%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%E5%90%8C%E6%A7%98%E3%81%AB%E3%80%81%E4%BB%96%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E5%8F%82%E7%85%A7%E3%82%82%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%8F%9B%3C%2FSPAN%3E%E3%81%97%E3%81%BE%E3%81%99%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3EPERIPHERAL-%26gt%3BREGISTER%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%E6%A7%8B%E6%96%87%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E7%89%B9%E5%AE%9A%E3%81%AE%E8%A1%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22token%22%3ESIM_SCGC5%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22token%22%3E%7C%3D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22token%22%3ESIM_SCGC5_PORTA_MASK%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22token%22%3E%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22token%22%3E%E3%81%AB%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22token%22%3ESIM-%26gt%3BSCGC5%20%7C%3D%20SIM_SCGC5_PORTA_MASK%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22token%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22token%22%3EBR%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22token%22%3E%E3%82%A2%E3%83%AA%E3%82%B9%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2388570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SIM%20Macro%20activation%20in%20MCUxpresso%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2388570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%A2%E3%83%AA%E3%82%B9%E3%81%95%E3%82%93%E3%80%81%E6%9C%AC%E5%BD%93%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AFSO%E3%81%A8%E3%81%A6%E3%82%82%E7%9F%A5%E8%AD%98%E8%B1%8A%E5%AF%8C%E3%81%A7%E3%80%81%E7%B0%A1%E5%8D%98%E3%81%AB%E8%A6%8B%E3%81%9B%E3%81%A6%E3%81%97%E3%81%BE%E3%81%86%E3%81%AE%E3%81%A7%E3%81%99%E3%81%AD!%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%ABCAN%E5%8F%96%E3%82%8A%E3%81%8B%E3%81%8B%E3%82%8B%20%3CLI-EMOJI%20id%3D%22lia_slightly-smiling-face%22%20title%3D%22%3Aslightly_smiling_face%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%3CP%3E%E4%B9%BE%E6%9D%AF%3C%2FP%3E%3CP%3E%E3%83%8A%E3%82%A4%E3%82%B8%E3%82%A7%E3%83%AB%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
