Hi Pavel,
Thanks for the reply.
Because it was working since 2020 till this failure occur, and I noticed the target voltage display did not register the expect 3.3V, we only tried to measure the target voltage on DUT (3.3V) and traced to the cable connection on the PARTH connector (3.3V).
Initial suspicion on Cyclone FX.not measuring what we are seeing on Volt meter; could it be internal issue on the Cyclone FX? Before we send for repair, we would like to find out if we can have other diagnosis method to determine if the Cyclone FX's at fault.
Benedict
