Configure Flash Security
864 次查看
giampietropompo
Hi All,
I'm working with the MK22FN1M0Axxx12, our solution is based on Bootloader + Custom Application.
Now, I should enable the Secure Mode and I'm able to enable it changing the definition of the Flash_Config ( defined into the file startup_*.c ) of the Bootloader.
We have many device in field so I should enable the secure mode by our application, I have done the same steps changing the file startup_*.c of the Application's project but it seems that it doesn't work.
So I have a doubs, is it possible enabling the secure mode from the application?
Giampietro Pomponio
0 回复数
