Cannot communicate with kboot v2
1,373 次查看
PedroCastro
I am trying to communicate with my TWR-KV31F with kboot v2 using another device through UART in order to transfer the .bin file. I read the kboot reference manual to understand the packet protocol, but I am not being successful yet. I would like to know if there is any open source code that already does what I am trying to accomplish or using an terminal in the host PC ou using some microcontroller.
Thanks in advance
1,274 次查看
kerryzhou
Hello Pedro Correa de Castro,
    Just as what I have replied you in your another post:
If you want to update the firmware without using the kinetis flashtool, just with other embedded, you need to write the code by yourself. we still don't have it.
  But i think you still can refer to the kinetis flash tool code, which you can find the source code in folder:
NXP_Kinetis_Bootloader_2_0_0\apps\KinetisFlashTool\KinetisFlashTool
Wish it helps you!
Kerry
