Hi everyone,
I try to program kv58f1m0vlq24 mcu on custom designed board with JTAG interface via pemicro u-multilink. When i click to debug button, debug session starts but terminates immediately after. So, i can not observe any problem or error on debug console. But when i try to program with "GUI Flash Tool" on mcuxpresso ide, i get errors. (errors on screenshot) Is there anyone can help?
解決済! 解決策の投稿を見る。
 Celeste_Liu
			Celeste_Liu
		Hello @kutay ,
I'd like to know does a similar error still happen when you try other debug tools?
Please attached the circuit of MCU(how did you connect it with MCU)?
You can also refer to the following post: How To Sucessfully Program a Custom made Kinetis Microcontroller Board. - NXP Community
Celeste
 Celeste_Liu
			Celeste_Liu
		Hello @kutay ,
Celeste
Thanks for answer and sorry for replying too late. My debugger pe-micro multilink is too old (estimately produced at 2015). So, i changed "Debug Shift Freq" in Target Communication Speed at debug configuration pane as 100 kHz. After made this change, i am be able to debug custom board.
Thank you for your time.
 Celeste_Liu
			Celeste_Liu
