USB Serial on frdm-k82f with Android
3,156 次查看
ajayan_e
I am working on the frdm-k82f:to have a serial communication between board and Android device.
But all the sample programs from the SDK I have tried was a failure.
The android device is able to detect the serial device.
but read and write is a failure as in it does not throw any error but no response from the board.
I am new to the firmware programming. Appreciate the help.
5 回复数
3,053 次查看
jingpan
Although FRDM-K82F has Arduino hardware interface, the SDK example doesn't support Arduino protocol. You have to port Arduino bootloader to it.
Jing
3,053 次查看
ajayan_e
So only with an Arduino protocol I can communicate to the board from an android device through serial port?
3,053 次查看
jingpan
Yes, otherwise how can MCU know what those command mean.
The arduino bootloader prototype is in arduino-1.8\hardware\arduino\avr\bootloaders. Of course you can search other one.
Jing
3,053 次查看
ajayan_e
I tried to do the boot loader and now the board is not at all recognized with windows. I did a drag and drop. I think i am lost
3,052 次查看
jingpan
You should migrate Atmega8 source code to K82, not just copy its bin file to K82. There is a lot of software work to do.
Jing
