Kinetis instruction set
orzel94
I have problem with instruction set in "my" project.
The main thing is that most of my program should be compiled in Toolchain but there is few files that needs ARM (because of some interrupts I gues)
I found how to do this but in makefile and Kinestis do not generate it:
https://www.embeddedrelated.com/showthread/lpc2000/22463-1.php
I add some screenshots of the project and errors I get
Microsoft OneDrive - Access files anywhere. Create docs with free Office Online.
P.S. The project had been done by someone else on some old version of Code Warrior  (I don't know which) and It was said to be ok but after some update it's stops to compile (I've tried on 10.4 and it don't work). I get it on university with words "make it works" (the teacher don't know how to repair it, only what he found with me is this instruction set)
Hello ,
Sorry I haven't know  your question clearly .
I find you use the chip of MKL05Z32, what about your project ?
Do you porting it to KDS from other IDE ? Or directly develop on KDS ?
Or could you please tell me the steps that reproduce your problem.
ALice
