KDS v3 Incremental build
4,751 次查看
Lupo
Is there an option in the new KDS v3 to set the incremental build?
It previously worked in the v2 but it does not work anymore (for me) in the v3...
4,301 次查看
BlackNight
Ian/Michael,
could it be that the problem is caused on your side with a wrong 'Refresh Policy' setting in the project?
See Eclipse Project ‘Refresh Policy': Broken Incremental Build with External Make? | MCU on Eclipse
Please let me know.
Erich
8 回复数
4,301 次查看
iscan
Hi Michael,
I am having the same problem after switching to KDS 3.0.  It DID work for the first couple of days after upgrading but can't get back to that point.  Any luck resolving this?
Ian
4,301 次查看
BlackNight
Ian,
could you describe a little bit more what your problem is (what is not working)? Just to be sure we are on the same page.
Erich
4,302 次查看
BlackNight
Ian/Michael,
Please let me know.
Erich
4,301 次查看
iscan
Fixed it!  Thanks.  I had already spent hours tracking this down today. I really appreciate your help.
This is what causes my problem: I copy and rename whole project directories and then import the "new" project into the workspace.  I have learned to update several parameters when I do this, so I guess I have a new one to add to the list.
You have a fantastic blog -thanks for sharing, it has saved me hours of work again.
Thanks again.
Ian
4,301 次查看
audi_mcavoy
Ian,
Would you consider posting your list of parameter changes?  I have spent the better part of a day trying to clone my project.
4,301 次查看
BlackNight
Hi Ian,
thanks for your confirmation!
And yes, it seems that copy of projects have caused that issue on my side too, and this issue was really hard to find. I know now things much better, and learned myself new things about Eclipse too :-)
Erich
4,301 次查看
Lupo
I'm a little late, but anyway, thanks a lot again for your help!
Michael
4,301 次查看
BlackNight
It should work by default (at least it does for me). However, I have seen a case where somehow it does not work for a Kinetis SDK project. Is this the case for you?
Erich
