KDS support
KDS support
4,071 次查看
cschlabach
I'm trying to build an SDK for FRDM-K66F utilizing KDS.  The SDK builder no longer has an option for Kinetis Design Studio as a toolchain.  Selecting "All toolchains" doesn't provide KDS support either.  This is a problem.
Has NXP officially discontinued supporting KDS?
KSDK‌ #kds
标记 (2)
3,793 次查看
ZhangJennie
Hi Clyde,
The latest SDK2.4 demo applications and driver examples are provided with projects for the following toolchains:
MCUXpresso IDE
GNU toolchain for Arm® Cortex® -M with Cmake build system
IAR Embedded Workbench
Keil™ MDK-Arm
See MCUXpresso SDK|NXP
" Supported Toolchains "
KDS is no longer supported.
Jennie Zhang
6 回复数
3,792 次查看
cschlabach
Case #: 00168019 created.
3,793 次查看
ZhangJennie
OK. I got it. I will check.
Jennie Zhang.
3,794 次查看
cschlabach
Just last month, I was able to build SDK 2.3.1 with KDS support for FRDM-K64F.  Due to supply issues, we are building our prototypes with K66 parts now.  Can someone send me an SDK 2.x build for FRDM-K66F with KDS support?
Clyde
3,794 次查看
ZhangJennie
For the moment, I don't know where to download the old versions.
I sent query email to SDK leader just now. I will let you know if I get a reply.
Jennie Zhang
3,794 次查看
ZhangJennie
Hi Clyde.
I was informed there is no SDK2.3.1 download link for external users.
If you need, please create a ticket, describe the requested configuration inside. we need apply it.
How to submit a new question for NXP Support
If you want, you can address to assign it to me. I can help.
Jennie Zhang
3,794 次查看
ZhangJennie
Hi Clyde,
MCUXpresso IDE
Keil™ MDK-Arm
Jennie Zhang
