KDS real time expression missing
1,725 次查看
claudiobrunelli
Hi.
I have to use KDS ide, althouhgt it's not recommended  for new design.
For some pc problem  I have done a new installation software but now I can not to use the real time expression viewer.
It's very easy to install it, but when I try to show the viewer in the perspective I can not see it. Before, I did these simple operation from menu "Window", "Show view", "Other" and in the PE menu I saw "realTime Expression". Now it's impossible. I have installed, disinstalled, updated but I see only.
Can someone give suggestion ?
Thanks in advance.
Claudio
1,555 次查看
BlackNight
Hi Claudio,
have you updated as well the PEMicro plugin using Help > Install new software using the P&E update site?
I hope this helps,
Erich
1,555 次查看
claudiobrunelli
Hi Erich.
Thanks for your assistance.
Yes I have updated the PE plugin.
But at the beginning, trying to install, I had an error as you can see from attached file named Image_B.
So I re-installed KDS IDE, updated pe plugin and checked again what I had installed.
I realized that I didn't have the right requirements named P&E Core Plugin 1.2.0 but I have P&E Core Plugin 1.1.43.
May be this the wrong situation (Image_C) ? Can you tell me how I can install P&E Core Plugin 1.2.0 ?
The view of PE that I have (without real time expression) is in Image_D.
Thanks for your suggestion.
Claudio
