S9KEAZN64AMLC core clock settings
已解决
跳至解决方案
1,643 次查看
vitaliharudka
Hello. I have made a board with S9KEAZN64AMLC microcontroller. Now i started writing code in Kinetis Design Studio and got some trouble. At first i had create a new project for this MCU. Most similar variant in KDS is SKEAZN64MLC2. I choise it. After this i tried to setup core clock frequency but it doesn't allow to set value more then 20MHz(40 mhz in spec). Where are my mistake? Thanks.
1 解答
1,524 次查看
Robin_Shen
Hi VITALI HARUDKA,
S9KEAZN64AMLC and SKEAZN64MLC2 are different.
The core clock limit for SKEAZN64MLC2 is 20MHz.
S9KEAZN64AMLC is not in the support list of Processor Expert KDS3.2.
Robin
在原帖中查看解决方案
1 回复
1,525 次查看
Robin_Shen
Hi VITALI HARUDKA,
Robin
