The linker file for K22 presents the RMA as two 64k blocks m_data and M_data_2. Presumably this is to prevent the risk of locating across the RAM boundaries etc. It locates the heap and stack into m_data_2 and bss into m_data. But otherwise leaves m_data_2 as empty.
I need more RAM! It seems odd to me not to have the unused space in m_data_2 used also for bss!
I tried to change the linker file and add a new section then locate my bigger arrays into this new section but I couldn't make it happen, instead the arrays just vanished from the map file!!!
Any advice on how to use all the available RAM?
Ashley
