How to find FRDM-KL03Z in kinetis design studio ?
已解决
跳至解决方案
5,652 次查看
volkancoskun
Hello I simply want to use kinetis design studio with ksdk 1.2.0 but when I start a new project and want to find the FRDM-KL03z processor it isnt located there ? Is there any way to add my board into the supported device list in kinetis design studio ?
标签 (1)
标记 (2)
1 解答
5,450 次查看
harshpatel
Hello
 Attached here with step by step images to create new project for FRDM-KL03z. please go through it.
  NOTE:  Hope you are using kinetis design studeo 3.1.0 and SDk 1.3.0.
Let me know if any....
MARK it as correct if this post answers your question.
Harsh
在原帖中查看解决方案
2 回复数
5,451 次查看
harshpatel
Hello
Harsh
5,450 次查看
DavidS
Hi Volkan,
I am assuming you are using KDS3.0 and have installed KSDK_1.2.
Now please read: C:\Freescale\KSDK_1.2.0\doc\Getting Started with Kinetis SDK (KSDK) v.1.2.pdf .
Start with chapter 5 Run a demo using Kinetis Design Studio IDE.
It will show you how to associate the KSDK1.2 to KDS.  This will allow KDS to know what devices/MCUs are supported with KSDK1.2.
When you create a new project, then KL03Z will be available and a new project will be instantiate with or without PE (Processor Expert) support (your decision).
Hope this helps.
David
