FRDM-KL26Z Board Components
2,233 次查看
frankbannon
Hi everyone,
I am learning to use KDS2.0 and working with a FRDM-KL26Z board.  I figured out how to use OpenSDA and upload the precompiled examples.
However, I would like to start a new design,  but I don't have a profile for FRDM-KL26Z.  There only seems to  be FRDM-64 profiles with KDS2.0
I did download the code examples for the FRDM--KL26Z Board but none are for KDS.  The closest is CW.  However, I am using the GNU compiler.  So, when I import the CW project, say for Hello World, there are too many preferences missing.
So....., does anyone know where I can get a FRDM-KL26Z profile/board components for KDS2.0?
Frank
2,030 次查看
ivadorazinova
Hi Frank Bannon,
for importing projects from CW to KDS  I can recommend the documentImporting MCU V10.6 projects (sample, using PE and MQX) under KDS
if you work with PEx, you can also create new project in KDS and copy and import PE component settings and copy PE components how is written
at Export and Import Processor Expert Component Settings | MCU on Eclipse and Copy of Processor Expert Components | MCU on Eclipse
I hope it helps you,
Iva
2,031 次查看
ivadorazinova
Hi Frank Bannon,
Iva
2,030 次查看
frankbannon
tx for the advice.
Frank
