Converting Code Warrior10.6 project in KDS not working
1,860 次查看
pallenna
Hi to all,
i am new to KDS IDE. i tried to importing a existing project from the Codewarrior 10.6 to KDS,and i followed the procedure of Importing MCU V10.6 projects (sample, using PE and MQX) under KDS, but it is not working. and i getting error as follows
make: *** [Test_TWR_K60DM100.elf] Error 1.
and i am sending the attachment please check it once,in this file if i did any mistakes please mention.
Thanks and Regards,
padmaja
标记 (2)
1,639 次查看
Carlos_Mendoza
Hi Pallenna,
Please take a look to the answer on your other post:
Hope it helps!
Carlos Mendoza
Technical Support Engineer
