Compression with K64
3,062 次查看
PO220
I work with K64 KDS and freertos
I need to compress a file who will be decompressed on a PC with winzip, winrar, 7zip and other usual tools.
I found compress/decompress library that generate unreadable files PC side
the most usefull i found is BCL
Basic Compression Library - an open source compression library (Huffman, RLE, LZ77, Rice, Shannon-Fa...
with many algorithms but unreadable...
there are zip libraries ?
should I do something else after the algorithm to obtain a readable zip?
Thank you in advance
2,856 次查看
PO220
2,856 次查看
TICS_Fiona
We do not supply the file compression library on K64 in KDS and FreeRTOS.  For compression algorithm and its open source, please search them in the book or resources for algorithms .Hope these links could help:
http://dotnetzip.codeplex.com/
http://sevenzipsharp.codeplex.com/
http://icsharpcode.github.io/SharpZipLib/
Best Regards
Fiona Kuang
TIC - Technical Information Center
