Can you use subversion with Kinetis Design Studio and if you can, would there be any documentation on how to best set it up?
Thx, Johnny
已解决! 转到解答。
Hi Johnny,
you can certainly use any Subersion plugin with Eclipse, I have used Subversive and Subclipse in the past (but moved to Git completely now).
Setting up/using Subversion with KDS is not different for any Eclipse based IDE (KDS is based on Eclipse Luna).
A few links:
http://stackoverflow.com/questions/61320/what-are-the-pros-and-cons-of-the-svn-plugins-for-eclipse-s...
Eclipse Subversive - Subversion (SVN) Team Provider
Subclipse | Eclipse Plugins, Bundles and Products - Eclipse Marketplace
I hope this helps,
Erich
Thanks Erich, after going through the above links, decided on Subclipse. Works great!
Cheers, J.
