Can you use Subversion easily with Kinetis Design Studio
1,321 次查看
johnnymclean
Can you use subversion with Kinetis Design Studio and if you can, would there be any documentation on how to best set it up?
Thx, Johnny
1,059 次查看
BlackNight
Hi Johnny,
you can certainly use any Subersion plugin with Eclipse, I have used Subversive and Subclipse in the past (but moved to Git completely now).
Setting up/using Subversion with KDS is not different for any Eclipse based IDE (KDS is based on Eclipse Luna).
A few links:
http://stackoverflow.com/questions/61320/what-are-the-pros-and-cons-of-the-svn-plugins-for-eclipse-s...
Eclipse Subversive - Subversion (SVN) Team Provider
Subclipse | Eclipse Plugins, Bundles and Products - Eclipse Marketplace
I hope this helps,
Erich
1,060 次查看
BlackNight
Hi Johnny,
A few links:
I hope this helps,
Erich
1,059 次查看
johnnymclean
Thanks Erich, after going through the above links, decided on Subclipse. Works great!
Cheers, J.
