GDB Debugging with Kinetis Design Studio
Outline
How to start debugging with the GDB debugging in KDS. If you are coming from CodeWarrior, then debugging with KDS is somewhat different because of the nature of GDB, and because the debug configuration panels look different.
This document uses
  1. FRDM-K64F board (Freescale Freedom Development Platform)
  2. Kinetis Design Studio V1.1.0.(Kinetis Design Studio Integrated Development)
  3. Screenshots from Windows 7 host (but things are very similar to any other host supported)
Creating Debug Configuration
In order to debug, a debug configuration needs to be created. It is assumed that you already have compiled/linked your project at this time.
In order to have most fields of the debug configuration pre-populated, select the project in the Project Explorer view:
Select the menu Run > Debug Configuration:
Alternatively, the debug icon drop down list can be used:
Kinetis Design Studio supports three different debugging connections:
  1. GDB OpenOCD Debugging: this uses the OpenOCD to CMSIS-DAP debug protocol, available with OpenSDAv2.0 (FRDM-K64F) or OpenSDAv2.1 (FRDM-K22F)
  2. GDB PEMicro Interface Debugging: this can be used for any P&E device (Multilink, or OSJAT/OpenSDA P&E firmware on a Freescale board)
  3. GDB SEGGER J-Link Debugging: this can be used with any Segger device (J-Link, or OpenSDA J-Link firmware on a Freescale board)
Once the configuration is created, I recommend to name it according t
Double click on one of the entries to create a new configuration for it. Instead double clicking you can use the 'New' icon as well:
What I recommend is to name the debug configuration. So I know later which configuration is for what. What I'm using is <project name><connection> like below:
Another thing I highly recommend is to save the debug configuration as file in the project (.launch). This allows sharing or passing the debug configuration with the project files.
To do this, I have 'Shared file' enabled:
That way the launch configuration files are stored in the project:
Then I need to fill out the fields for the debug configuration.
The details are listed in DS Debug Configurations (OpenOCD, P&E, Segger), and listed here again:
For OpenOCD, use "-f kinetis.cfg" which is the same for all Kinetis devices:
For P&E: select the interface, port and device:
For Segger, specify device name, interface (use JTAG only if you know the debug header supports JTAG. If in doubt, choose SWD):
SWO (Single Wire Output) is an extra pin to SWD/JTAG, and currently not supported on FRDM boards. So I disable that option for my FRDM boards, as otherwise the debugger will complain later about it:
Debugging and Debug Icon
To Debug, one way is to use the 'Debug' button from the Debug Configuration dialog:
You have to do this at least once.
Once you have done that, then you can use the drop down of the Debug icon:
Just pressing the 'Debug' Icon is in general NOT recommended if it does not show in the tooltip a launch configuration:
And if you get the dialog below:
DO NOT select either gdbserver or remote gdb/mi: it does not work that way :-(
Press Cancel, and select it from the list, or select it from the 'Debug Configurations...' dialog:
Although KDS V1.1.0 has improved in this area, it is possible that it will show you a selection of launch/debug configurations (then you are ok to choose one):
The recommended way is to use the drop down list and to select the desired debug/launch configuration:
Trouble Shooting
If debugging does not work, here are a few trouble shooting tips:
Settings: verify that your launch configuration settiings are ok. That you are debugging the correct board with the correct connection (P&E, OpenOCD, Segger).
Power: Verify that your board has power and connected with the correct USB port on the board.
Not Debugging Twice: Make sure that you are *not* debugging the same application board twice, or you will get this:
Because the board is already running a debug session:
Always terminate an existing debug session before starting a new one:
Kill any Zombies: the gdb client and server are usually terminated after a debug session. After terminating a debug session, verify that these services are *not* present any more in your task manager (Windows):
  1. arm-none-eabi-gdb.exe: this is the ARM GDB client, needed for the OpenOCD, Segger and P&E servers listed below
  2. openocd.exe: this is the OpenOCD GDB server
  3. pegdbserver_console.exe: this is the P&E GDB Server
  4. JLinkGDBServerCL.exe: this is the Segger GDB Server
If you see multiple zombies/instances like this: kill them:
Links
评论
pgo
I just thought it might be useful to describe the above process as applied to creating a GDB launcher for a USBDM debug interface.
USBDM: USBDM Debugger interface for Freescale RS08,HCS08,HCS12,Coldfire and ARM-Kinetis Devices.
Note that this process is not necessary if you create a project using the USBDM new project wizard.
Assumes the following:
  • KDS
  • USBDM installed after KDS so that the required plugins are installed.
  • A FRDM-K22F board with USBDM firmware.
  • An existing project without any current launch configuration (the usual situation if a project has just been created)
  1. Select the project in the Project Explorer and make sure that it has been successfully built.
  3. Open the drop-down next to the debug button and select Debug Configurations:
  5. Select the USBDM Hardware Debugging group and select new from the right-click menu or the new icon at the top of the dialogue.
  7. The dialogue that open is similar to a standard Eclipse Launch configuration.  The first page should be correctly fill out providing an existing correctly built project was selected earlier.  You can use the browse button to select other build targets if desired.  IN the example shown the Debug build was currently selected in the build target (project selected).
  9. The second tab will usually need modification  The most important items are the Target Device selection and the target Vdd (only needed for targets with switchable target power such as K22F). You can also the  change the socket used by GDB if desired. This may be needed if you want to debug multiple targets using two instances of KDS.
  11. You should now be able to launch the configuration using the Launch button.
  12. The USBDM GDB Server will be started as a separate process with its own GUI window:
  14. After launching the target registers may be examined in the Peripheral view.
Comments about troubleshooting given in Erich's posting should be equally useful with USBDM launches.
Why is it always necessary to terminate the last debugging session before starting a new one. This is not the way it was in Code Warrior. Is there anyway to workaround this or fix this?
Hi David,
It is a problem how Eclipse GDB launches the debug session, or how the started session checks if it is already running. This needs to be done at the plugin level. CodeWarrior has it implemented as it is using its own debug engine.
Normal GDB launcher plugins do not check this.
I'm only aware that the GNU ARM Eclipse one (which is in KDS v3.0.0) can check if there is already a debug session running, and offers this dialog:
But it is for Segger J-Link only (P&E and OpenOCD have not implemented that (yet?)).
So the workaround is to use J-Link in that case. For P&E or OpenOCD you have to terminate the debug session first.
Erich
%3CLINGO-SUB%20id%3D%22lingo-sub-1114643%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%BF%E7%94%A8%20Kinetis%20Design%20Studio%20%E8%BF%9B%E8%A1%8C%20GDB%20%E8%B0%83%E8%AF%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114643%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH3%20id%3D%22toc-hId-1082598131%22%20id%3D%22toc-hId-2005286100%22%3E%E6%A6%82%E8%BF%B0%3C%2FH3%3E%3CP%3E%E5%A6%82%E4%BD%95%E5%9C%A8%20KDS%20%E4%B8%AD%E4%BD%BF%E7%94%A8%20GDB%20%E8%B0%83%E8%AF%95%E5%BC%80%E5%A7%8B%E8%B0%83%E8%AF%95%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E6%9D%A5%E8%87%AA%20CodeWarrior%EF%BC%8C%E9%82%A3%E4%B9%88%E4%BD%BF%E7%94%A8%20KDS%20%E8%BF%9B%E8%A1%8C%E8%B0%83%E8%AF%95%E4%BC%9A%E6%9C%89%E6%89%80%E4%B8%8D%E5%90%8C%EF%BC%8C%E5%9B%A0%E4%B8%BA%20GDB%20%E7%9A%84%E6%80%A7%E8%B4%A8%EF%BC%8C%E5%B9%B6%E4%B8%94%E8%B0%83%E8%AF%95%E9%85%8D%E7%BD%AE%E9%9D%A2%E6%9D%BF%E7%9C%8B%E8%B5%B7%E6%9D%A5%E4%B8%8D%E5%90%8C%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E6%9C%AC%E6%96%87%E6%A1%A3%E4%BD%BF%E7%94%A8%3C%2FP%3E%3COL%3E%3CLI%3EFRDM-K64F%20%E5%BC%80%E5%8F%91%E6%9D%BF%EF%BC%88%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.freescale.com%252Ffreedom%22%20target%3D%22_blank%22%3E%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%20Freedom%20%E5%BC%80%E5%8F%91%E5%B9%B3%E5%8F%B0%3C%2FA%3E%EF%BC%89%3C%2FLI%3E%3CLI%3EKinetis%20Design%20Studio%20V1.1.0.%EF%BC%88%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.freescale.com%252Fkds%22%20target%3D%22_blank%22%3EKinetis%20Design%20Studio%E9%9B%86%E6%88%90%E5%BC%80%E5%8F%91%3C%2FA%3E%EF%BC%89%3C%2FLI%3E%3CLI%3E%E6%9D%A5%E8%87%AA%20Windows%207%20%E4%B8%BB%E6%9C%BA%E7%9A%84%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%EF%BC%88%E4%BD%86%E5%86%85%E5%AE%B9%E4%B8%8E%E4%BB%BB%E4%BD%95%E5%85%B6%E4%BB%96%E5%8F%97%E6%94%AF%E6%8C%81%E7%9A%84%E4%B8%BB%E6%9C%BA%E9%9D%9E%E5%B8%B8%E7%9B%B8%E4%BC%BC%EF%BC%89%3C%2FLI%3E%3C%2FOL%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CH3%20id%3D%22toc-hId--724856332%22%20id%3D%22toc-hId-197831637%22%3E%E5%88%9B%E5%BB%BA%E8%B0%83%E8%AF%95%E9%85%8D%E7%BD%AE%3C%2FH3%3E%3CP%3E%E4%B8%BA%E4%BA%86%E8%BF%9B%E8%A1%8C%E8%B0%83%E8%AF%95%EF%BC%8C%E9%9C%80%E8%A6%81%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E8%B0%83%E8%AF%95%E9%85%8D%E7%BD%AE%E3%80%82%E5%81%87%E8%AE%BE%E6%82%A8%E6%AD%A4%E6%97%B6%E5%B7%B2%E7%BB%8F%E7%BC%96%E8%AF%91%2F%E9%93%BE%E6%8E%A5%E4%BA%86%E6%82%A8%E7%9A%84%E9%A1%B9%E7%9B%AE%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E4%B8%BA%E4%BA%86%E9%A2%84%E5%85%88%E5%A1%AB%E5%85%85%E8%B0%83%E8%AF%95%E9%85%8D%E7%BD%AE%E7%9A%84%E5%A4%A7%E5%A4%9A%E6%95%B0%E5%AD%97%E6%AE%B5%EF%BC%8C%E8%AF%B7%E5%9C%A8%E9%A1%B9%E7%9B%AE%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%E8%A7%86%E5%9B%BE%E4%B8%AD%E9%80%89%E6%8B%A9%E9%A1%B9%E7%9B%AE%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213967_13967.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213967_13967.png%22%20style%3D%22width%3A%20240px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117719i72F9BD35D0282BBC%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2213967_13967.png%22%20alt%3D%2213967_13967.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E13967_13967.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20240px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F45693i66B0432F100A767C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E9%80%89%E6%8B%A9%E8%8F%9C%E5%8D%95%E8%BF%90%E8%A1%8C%26gt%3B%E8%B0%83%E8%AF%95%E9%85%8D%E7%BD%AE%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213968_13968.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213968_13968.png%22%20style%3D%22width%3A%20302px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117720i8FEF635BB121CD2C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2213968_13968.png%22%20alt%3D%2213968_13968.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E13968_13968.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20302px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F45695i2BD7345E9EC9A32D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%96%E8%80%85%EF%BC%8C%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E8%B0%83%E8%AF%95%E5%9B%BE%E6%A0%87%E4%B8%8B%E6%8B%89%E5%88%97%E8%A1%A8%EF%BC%9A%3C%2FP%3E%3CP%3E%3CIMG%20alt%3D%22%22%20class%3D%22jiveImage%22%20style%3D%22max-width%3A%201200px%3B%20max-height%3A%20900px%3B%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CP%3E%3C%2FP%3E%3CP%3EKinetis%20Design%20Studio%20%E6%94%AF%E6%8C%81%E4%B8%89%E7%A7%8D%E4%B8%8D%E5%90%8C%E7%9A%84%E8%B0%83%E8%AF%95%E8%BF%9E%E6%8E%A5%EF%BC%9A%3C%2FP%3E%3COL%3E%3CLI%3EGDB%20OpenOCD%20%E8%B0%83%E8%AF%95%EF%BC%9A%E4%BD%BF%E7%94%A8%20OpenOCD%20%E5%88%B0%20CMSIS-DAP%20%E8%B0%83%E8%AF%95%E5%8D%8F%E8%AE%AE%EF%BC%8C%E5%8F%AF%E4%B8%8E%20OpenSDAv2.0%20%E4%B8%80%E8%B5%B7%E4%BD%BF%E7%94%A8%EF%BC%88FRDM-K64F%EF%BC%89%E6%88%96OpenSDAv2.1%EF%BC%88FRDM-K22F%EF%BC%89%3C%2FLI%3E%3CLI%3EGDB%20PEMicro%20%E6%8E%A5%E5%8F%A3%E8%B0%83%E8%AF%95%EF%BC%9A%E5%8F%AF%E7%94%A8%E4%BA%8E%E4%BB%BB%E4%BD%95%20P%26amp%3BE%20%E8%AE%BE%E5%A4%87%EF%BC%88Multilink%EF%BC%8C%E6%88%96%20Freescale%20%E6%9D%BF%E4%B8%8A%E7%9A%84%20OSJAT%2FOpenSDA%20P%26amp%3BE%20%E5%9B%BA%E4%BB%B6%EF%BC%89%3C%2FLI%3E%3CLI%3EGDB%20SEGGER%20J-Link%20%E8%B0%83%E8%AF%95%EF%BC%9A%E5%8F%AF%E4%B8%8E%E4%BB%BB%E4%BD%95%20Segger%20%E8%AE%BE%E5%A4%87%EF%BC%88J-Link%20%E6%88%96%20Freescale%20%E6%9D%BF%E4%B8%8A%E7%9A%84%20OpenSDA%20J-Link%20%E5%9B%BA%E4%BB%B6%EF%BC%89%E4%B8%80%E8%B5%B7%E4%BD%BF%E7%94%A8%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213971_13971.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213971_13971.png%22%20style%3D%22width%3A%20276px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117721i28516AFAFEAB64B2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2213971_13971.png%22%20alt%3D%2213971_13971.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E13971_13971.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22GDB%20Debug%20Launch%20Configurations.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22GDB%20Debug%20Launch%20Configurations.png%22%20style%3D%22width%3A%20276px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F45696i5A5F18AE913A83CA%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22GDB%20Debug%20Launch%20Configurations.png%22%20alt%3D%22GDB%20Debug%20Launch%20Configurations.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EGDB%20Debug%20Launch%20Configurations.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%B8%80%E6%97%A6%E5%88%9B%E5%BB%BA%E4%BA%86%E9%85%8D%E7%BD%AE%EF%BC%8C%E6%88%91%E5%BB%BA%E8%AE%AE%E6%A0%B9%E6%8D%AE%3C%2FP%3E%3CP%3E%E5%8F%8C%E5%87%BB%E5%85%B6%E4%B8%AD%E4%B8%80%E4%B8%AA%E6%9D%A1%E7%9B%AE%E5%8D%B3%E5%8F%AF%E4%B8%BA%E5%85%B6%E5%88%9B%E5%BB%BA%E6%96%B0%E7%9A%84%E9%85%8D%E7%BD%AE%E3%80%82%E6%82%A8%E4%B9%9F%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E2%80%9C%E6%96%B0%E5%BB%BA%E2%80%9D%E5%9B%BE%E6%A0%87%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E5%8F%8C%E5%87%BB%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213972_13972.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213972_13972.png%22%20style%3D%22width%3A%20329px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117722iBE30B912F4897566%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2213972_13972.png%22%20alt%3D%2213972_13972.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E13972_13972.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Click%20and%20Create.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Click%20and%20Create.png%22%20style%3D%22width%3A%20329px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F45699iFD4B8F4B4EA03948%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Click%20and%20Create.png%22%20alt%3D%22Click%20and%20Create.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EClick%20and%20Create.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%BB%BA%E8%AE%AE%E5%AF%B9%E8%B0%83%E8%AF%95%E9%85%8D%E7%BD%AE%E8%BF%9B%E8%A1%8C%E5%91%BD%E5%90%8D%E3%80%82%E6%89%80%E4%BB%A5%E6%88%91%E5%90%8E%E6%9D%A5%E7%9F%A5%E9%81%93%E5%93%AA%E7%A7%8D%E9%85%8D%E7%BD%AE%E6%98%AF%E7%94%A8%E4%BA%8E%E4%BB%80%E4%B9%88%E7%9A%84%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%E7%9A%84%20%3CPROJECT%20name%3D%22%22%3E%3CCONNECTION%3E%EF%BC%9A%3C%2FCONNECTION%3E%3C%2FPROJECT%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213975_13975.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213975_13975.png%22%20style%3D%22width%3A%20594px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117723iD64F525751A15C37%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2213975_13975.png%22%20alt%3D%2213975_13975.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E13975_13975.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Naming%20Debug%20Configurations.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Naming%20Debug%20Configurations.png%22%20style%3D%22width%3A%20594px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F45692iC5F18860160FC8C4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Naming%20Debug%20Configurations.png%22%20alt%3D%22Naming%20Debug%20Configurations.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ENaming%20Debug%20Configurations.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%BC%BA%E7%83%88%E5%BB%BA%E8%AE%AE%E7%9A%84%E5%8F%A6%E4%B8%80%E4%BB%B6%E4%BA%8B%E6%98%AF%E5%B0%86%E8%B0%83%E8%AF%95%E9%85%8D%E7%BD%AE%E4%BF%9D%E5%AD%98%E4%B8%BA%E9%A1%B9%E7%9B%AE%E4%B8%AD%E7%9A%84%E6%96%87%E4%BB%B6%EF%BC%88.launch%EF%BC%89%E3%80%82%E8%BF%99%E5%85%81%E8%AE%B8%E4%B8%8E%E9%A1%B9%E7%9B%AE%E6%96%87%E4%BB%B6%E5%85%B1%E4%BA%AB%E6%88%96%E4%BC%A0%E9%80%92%E8%B0%83%E8%AF%95%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%BA%E6%AD%A4%EF%BC%8C%E6%88%91%E5%90%AF%E7%94%A8%E4%BA%86%E2%80%9C%E5%85%B1%E4%BA%AB%E6%96%87%E4%BB%B6%E2%80%9D%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213976_13976.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213976_13976.png%22%20style%3D%22width%3A%20672px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117724i144B2232D2972849%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2213976_13976.png%22%20alt%3D%2213976_13976.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E13976_13976.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sharing%20Debug%20Configuration.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sharing%20Debug%20Configuration.png%22%20style%3D%22width%3A%20672px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F45691iB7AABF19FCDD67A9%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Sharing%20Debug%20Configuration.png%22%20alt%3D%22Sharing%20Debug%20Configuration.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESharing%20Debug%20Configuration.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E6%A0%B7%EF%BC%8C%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E5%B0%B1%E5%AD%98%E5%82%A8%E5%9C%A8%E9%A1%B9%E7%9B%AE%E4%B8%AD%E4%BA%86%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213977_13977.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213977_13977.png%22%20style%3D%22width%3A%20273px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117725i602083D3DC1B6C83%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2213977_13977.png%22%20alt%3D%2213977_13977.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E13977_13977.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Launch%20Config%20Files%20in%20project.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Launch%20Config%20Files%20in%20project.png%22%20style%3D%22width%3A%20273px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F45688i95F7DF91961826BA%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Launch%20Config%20Files%20in%20project.png%22%20alt%3D%22Launch%20Config%20Files%20in%20project.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ELaunch%20Config%20Files%20in%20project.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%E6%88%91%E9%9C%80%E8%A6%81%E5%A1%AB%E5%86%99%E8%B0%83%E8%AF%95%E9%85%8D%E7%BD%AE%E7%9A%84%E5%AD%97%E6%AE%B5%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%E5%88%97%E5%9C%A8%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%2211213%22%20data-containertype%3D%2214%22%20data-objectid%3D%22100705%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-100705%22%20target%3D%22_blank%22%3EDS%20%E8%B0%83%E8%AF%95%E9%85%8D%E7%BD%AE%EF%BC%88OpenOCD%E3%80%81P%26amp%3BE%E3%80%81Segger%EF%BC%89%3C%2FA%3E%E4%B8%AD%EF%BC%8C%E5%B9%B6%E5%9C%A8%E6%AD%A4%E5%A4%84%E5%86%8D%E6%AC%A1%E5%88%97%E5%87%BA%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E5%AF%B9%E4%BA%8E%3CSTRONG%3EOpenOCD%3C%2FSTRONG%3E%20%EF%BC%8C%E4%BD%BF%E7%94%A8%E2%80%9C-f%20kinetis.cfg%E2%80%9D%E5%AF%B9%E4%BA%8E%E6%89%80%E6%9C%89%20Kinetis%20%E8%AE%BE%E5%A4%87%E6%9D%A5%E8%AF%B4%E9%83%BD%E6%98%AF%E7%9B%B8%E5%90%8C%E7%9A%84%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213973_13973.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213973_13973.png%22%20style%3D%22width%3A%20672px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117726i8CB98EE27A0F411D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2213973_13973.png%22%20alt%3D%2213973_13973.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E13973_13973.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OpenOCD%20config.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OpenOCD%20config.png%22%20style%3D%22width%3A%20672px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F45700iF113028DA6DE65C8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22OpenOCD%20config.png%22%20alt%3D%22OpenOCD%20config.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EOpenOCD%20config.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E5%AF%B9%E4%BA%8E%3CSTRONG%3EP%26amp%3BE%3C%2FSTRONG%3E%20%EF%BC%9A%E9%80%89%E6%8B%A9%E6%8E%A5%E5%8F%A3%E3%80%81%E7%AB%AF%E5%8F%A3%E5%92%8C%E8%AE%BE%E5%A4%87%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213974_13974.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213974_13974.png%22%20style%3D%22width%3A%20672px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117727i234C06AB1A15E075%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2213974_13974.png%22%20alt%3D%2213974_13974.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E13974_13974.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PnE%20Settings.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PnE%20Settings.png%22%20style%3D%22width%3A%20672px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F45702iC4746577483B5715%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22PnE%20Settings.png%22%20alt%3D%22PnE%20Settings.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EPnE%20Settings.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E5%AF%B9%E4%BA%8E%3CSTRONG%3ESegger%3C%2FSTRONG%3E%20%EF%BC%8C%E6%8C%87%E5%AE%9A%E8%AE%BE%E5%A4%87%E5%90%8D%E7%A7%B0%E3%80%81%E6%8E%A5%E5%8F%A3%EF%BC%88%E4%BB%85%E5%BD%93%E6%82%A8%E7%9F%A5%E9%81%93%E8%B0%83%E8%AF%95%E5%A4%B4%E6%94%AF%E6%8C%81%20JTAG%20%E6%97%B6%E6%89%8D%E4%BD%BF%E7%94%A8%20JTAG%E3%80%82%E5%A6%82%E6%9C%89%E7%96%91%E9%97%AE%EF%BC%8C%E8%AF%B7%E9%80%89%E6%8B%A9%20SWD)%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213978_13978.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213978_13978.png%22%20style%3D%22width%3A%20672px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117728iF578D2DC89C60E75%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2213978_13978.png%22%20alt%3D%2213978_13978.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E13978_13978.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Segger%20Debug%20Settings.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Segger%20Debug%20Settings.png%22%20style%3D%22width%3A%20672px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F45687iAAA23C05BA79F663%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Segger%20Debug%20Settings.png%22%20alt%3D%22Segger%20Debug%20Settings.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESegger%20Debug%20Settings.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3ESWO%EF%BC%88%E5%8D%95%E7%BA%BF%E8%BE%93%E5%87%BA%EF%BC%89%E6%98%AF%20SWD%2FJTAG%20%E7%9A%84%E9%A2%9D%E5%A4%96%E5%BC%95%E8%84%9A%EF%BC%8C%E7%9B%AE%E5%89%8D%E4%B8%8D%E5%8F%97%20FRDM%20%E6%9D%BF%E6%94%AF%E6%8C%81%E3%80%82%E5%9B%A0%E6%AD%A4%E6%88%91%E4%B8%BA%E6%88%91%E7%9A%84%20FRDM%20%E6%9D%BF%E7%A6%81%E7%94%A8%E4%BA%86%E8%AF%A5%E9%80%89%E9%A1%B9%EF%BC%8C%E5%90%A6%E5%88%99%E8%B0%83%E8%AF%95%E5%99%A8%E7%A8%8D%E5%90%8E%E4%BC%9A%E5%AF%B9%E6%AD%A4%E5%8F%91%E5%87%BA%E6%8A%B1%E6%80%A8%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213979_13979.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213979_13979.png%22%20style%3D%22width%3A%20672px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117729iB61990A050D88327%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2213979_13979.png%22%20alt%3D%2213979_13979.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E13979_13979.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Segger%20Startup%20Settings.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Segger%20Startup%20Settings.png%22%20style%3D%22width%3A%20672px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F45684iE1FBB32893EDE3E2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Segger%20Startup%20Settings.png%22%20alt%3D%22Segger%20Startup%20Settings.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESegger%20Startup%20Settings.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1762656501%22%20id%3D%22toc-hId--1609622826%22%3E%E8%B0%83%E8%AF%95%E5%92%8C%E8%B0%83%E8%AF%95%E5%9B%BE%E6%A0%87%3C%2FH3%3E%3CP%3E%E8%A6%81%E8%BF%9B%E8%A1%8C%E8%B0%83%E8%AF%95%EF%BC%8C%E4%B8%80%E7%A7%8D%E6%96%B9%E6%B3%95%E6%98%AF%E4%BD%BF%E7%94%A8%E2%80%9C%E8%B0%83%E8%AF%95%E9%85%8D%E7%BD%AE%E2%80%9D%E5%AF%B9%E8%AF%9D%E6%A1%86%E4%B8%AD%E7%9A%84%E2%80%9C%E8%B0%83%E8%AF%95%E2%80%9D%E6%8C%89%E9%92%AE%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213980_13980.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213980_13980.png%22%20style%3D%22width%3A%20752px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117730iAA56E2985498EA0D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2213980_13980.png%22%20alt%3D%2213980_13980.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E13980_13980.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Debug%20Button.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Debug%20Button.png%22%20style%3D%22width%3A%20752px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F45683iEB5570515D504FB4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Debug%20Button.png%22%20alt%3D%22Debug%20Button.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EDebug%20Button.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BD%A0%E5%BF%85%E9%A1%BB%E8%87%B3%E5%B0%91%E5%81%9A%E4%B8%80%E6%AC%A1%E8%BF%99%E4%B8%AA%E3%80%82%3C%2FP%3E%3CP%3E%E5%AE%8C%E6%88%90%E5%90%8E%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E8%B0%83%E8%AF%95%E5%9B%BE%E6%A0%87%E7%9A%84%E4%B8%8B%E6%8B%89%E8%8F%9C%E5%8D%95%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213981_13981.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213981_13981.png%22%20style%3D%22width%3A%20260px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117731i1D0DAD1A974B44F9%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2213981_13981.png%22%20alt%3D%2213981_13981.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E13981_13981.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.png%22%20style%3D%22width%3A%20260px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F45681i5368F5024D657A80%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_6.png%22%20alt%3D%22pastedImage_6.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_6.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E5%B7%A5%E5%85%B7%E6%8F%90%E7%A4%BA%E4%B8%AD%E6%B2%A1%E6%9C%89%E6%98%BE%E7%A4%BA%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%EF%BC%8C%E9%80%9A%E5%B8%B8%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%3CSTRONG%3E%E4%B8%8D%3C%2FSTRONG%3E%3C%2FSPAN%3E%E5%BB%BA%E8%AE%AE%E7%9B%B4%E6%8E%A5%E6%8C%89%E4%B8%8B%E2%80%9C%E8%B0%83%E8%AF%95%E2%80%9D%E5%9B%BE%E6%A0%87%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213982_13982.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213982_13982.png%22%20style%3D%22width%3A%2094px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117732iD0DE68446B2010EB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2213982_13982.png%22%20alt%3D%2213982_13982.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E13982_13982.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%20style%3D%22width%3A%2094px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F45680i6EC0EF259ACDEE6E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_7.png%22%20alt%3D%22pastedImage_7.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_7.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E7%9C%8B%E5%88%B0%E4%B8%8B%E9%9D%A2%E7%9A%84%E5%AF%B9%E8%AF%9D%E6%A1%86%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E4%B8%8D%E8%A6%81%3C%2FSTRONG%3E%E9%80%89%E6%8B%A9%20gdbserver%20%E6%88%96%E8%BF%9C%E7%A8%8B%20gdb%2Fmi%EF%BC%9A%E8%BF%99%E6%A0%B7%E4%B8%8D%E8%A1%8C%3A-(%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214072_14072.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214072_14072.png%22%20style%3D%22width%3A%20398px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117733i3A091A4CCCAD96C0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2214072_14072.png%22%20alt%3D%2214072_14072.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E14072_14072.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Launch%20Debug%20Configuration%20Selection%20which%20is%20a%20dead%20end.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Launch%20Debug%20Configuration%20Selection%20which%20is%20a%20dead%20end.png%22%20style%3D%22width%3A%20398px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F13881i77E5C2D3D80C51D2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Launch%20Debug%20Configuration%20Selection%20which%20is%20a%20dead%20end.png%22%20alt%3D%22Launch%20Debug%20Configuration%20Selection%20which%20is%20a%20dead%20end.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ELaunch%20Debug%20Configuration%20Selection%20which%20is%20a%20dead%20end.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%8C%89%E2%80%9C%E5%8F%96%E6%B6%88%E2%80%9D%EF%BC%8C%E7%84%B6%E5%90%8E%E4%BB%8E%E5%88%97%E8%A1%A8%E4%B8%AD%E9%80%89%E6%8B%A9%E5%AE%83%EF%BC%8C%E6%88%96%E8%80%85%E4%BB%8E%E2%80%9C%E8%B0%83%E8%AF%95%E9%85%8D%E7%BD%AE...%E2%80%9D%E5%AF%B9%E8%AF%9D%E6%A1%86%E4%B8%AD%E9%80%89%E6%8B%A9%E5%AE%83%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214073_14073.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2214073_14073.png%22%20style%3D%22width%3A%20242px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117734i399B41BABE3D9B27%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2214073_14073.png%22%20alt%3D%2214073_14073.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E14073_14073.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20242px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F13883iFC3648F2D45FC06F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E5%B0%BD%E7%AE%A1KDS%20V1.1.0%E5%9C%A8%E6%AD%A4%E6%96%B9%E9%9D%A2%E6%9C%89%E6%89%80%E6%94%B9%E8%BF%9B%EF%BC%8C%E5%AE%83%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%90%91%E6%82%A8%E6%98%BE%E7%A4%BA%E5%90%AF%E5%8A%A8%2F%E8%B0%83%E8%AF%95%E9%85%8D%E7%BD%AE%E7%9A%84%E9%80%89%E6%8B%A9%EF%BC%88%E7%84%B6%E5%90%8E%E6%82%A8%E5%8F%AF%E4%BB%A5%E9%80%89%E6%8B%A9%E4%B8%80%E4%B8%AA%EF%BC%89%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213983_13983.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213983_13983.png%22%20style%3D%22width%3A%20398px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117735iE8AC346F7BED9083%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2213983_13983.png%22%20alt%3D%2213983_13983.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E13983_13983.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Launch%20Configuration%20Selection.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Launch%20Configuration%20Selection.png%22%20style%3D%22width%3A%20398px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F45679iF302A463CC27BE71%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Launch%20Configuration%20Selection.png%22%20alt%3D%22Launch%20Configuration%20Selection.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ELaunch%20Configuration%20Selection.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%8E%A8%E8%8D%90%E7%9A%84%E6%96%B9%E6%B3%95%E6%98%AF%E4%BD%BF%E7%94%A8%E4%B8%8B%E6%8B%89%E5%88%97%E8%A1%A8%E5%B9%B6%E9%80%89%E6%8B%A9%E6%89%80%E9%9C%80%E7%9A%84%E8%B0%83%E8%AF%95%2F%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213988_13988.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213988_13988.png%22%20style%3D%22width%3A%20284px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117736i3DAF7C8CBEDBA6F1%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2213988_13988.png%22%20alt%3D%2213988_13988.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E13988_13988.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%20style%3D%22width%3A%20284px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F13864i8F61630D3F529A0C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_0.png%22%20alt%3D%22pastedImage_0.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_0.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CH3%20id%3D%22toc-hId--44797962%22%20id%3D%22toc-hId-877890007%22%3E%E6%95%85%E9%9A%9C%E6%8E%92%E9%99%A4%3C%2FH3%3E%3CP%3E%E5%A6%82%E6%9E%9C%E8%B0%83%E8%AF%95%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%EF%BC%8C%E8%BF%99%E9%87%8C%E6%9C%89%E4%B8%80%E4%BA%9B%E6%95%85%E9%9A%9C%E6%8E%92%E9%99%A4%E6%8F%90%E7%A4%BA%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E8%AE%BE%E7%BD%AE%3C%2FSTRONG%3E%EF%BC%9A%E9%AA%8C%E8%AF%81%E6%82%A8%E7%9A%84%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%E8%AE%BE%E7%BD%AE%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%E3%80%82%E6%82%A8%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E6%AD%A3%E7%A1%AE%E7%9A%84%E8%BF%9E%E6%8E%A5%EF%BC%88P%26amp%3BE%E3%80%81OpenOCD%E3%80%81Segger%EF%BC%89%E8%B0%83%E8%AF%95%E6%AD%A3%E7%A1%AE%E7%9A%84%E7%94%B5%E8%B7%AF%E6%9D%BF%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E7%94%B5%E6%BA%90%3C%2FSTRONG%3E%EF%BC%9A%E9%AA%8C%E8%AF%81%E6%82%A8%E7%9A%84%E5%BC%80%E5%8F%91%E6%9D%BF%E6%98%AF%E5%90%A6%E6%9C%89%E7%94%B5%E6%BA%90%E5%B9%B6%E4%B8%94%E6%98%AF%E5%90%A6%E8%BF%9E%E6%8E%A5%E5%88%B0%E5%BC%80%E5%8F%91%E6%9D%BF%E4%B8%8A%E6%AD%A3%E7%A1%AE%E7%9A%84%20USB%20%E7%AB%AF%E5%8F%A3%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E4%B8%8D%E8%A6%81%E8%B0%83%E8%AF%95%E4%B8%A4%E6%AC%A1%3C%2FSTRONG%3E%EF%BC%9A%E7%A1%AE%E4%BF%9D%E6%82%A8%E6%B2%A1%E6%9C%89%E5%AF%B9%E5%90%8C%E4%B8%80%E4%B8%AA%E5%BA%94%E7%94%A8%E6%9D%BF%E8%BF%9B%E8%A1%8C%E4%B8%A4%E6%AC%A1%E8%B0%83%E8%AF%95%EF%BC%8C%E5%90%A6%E5%88%99%E6%82%A8%E5%B0%86%E5%BE%97%E5%88%B0%E4%BB%A5%E4%B8%8B%E7%BB%93%E6%9E%9C%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213984_13984.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213984_13984.png%22%20style%3D%22width%3A%20378px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117737iAA1142E8092F564E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2213984_13984.png%22%20alt%3D%2213984_13984.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E13984_13984.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Failed%20to%20Debug%20debugging%20target%20twice.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Failed%20to%20Debug%20debugging%20target%20twice.png%22%20style%3D%22width%3A%20378px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F45676iED165C3E6BE7E4EB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Failed%20to%20Debug%20debugging%20target%20twice.png%22%20alt%3D%22Failed%20to%20Debug%20debugging%20target%20twice.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFailed%20to%20Debug%20debugging%20target%20twice.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%9B%A0%E4%B8%BA%E5%BC%80%E5%8F%91%E6%9D%BF%E5%B7%B2%E7%BB%8F%E5%9C%A8%E8%BF%90%E8%A1%8C%E8%B0%83%E8%AF%95%E4%BC%9A%E8%AF%9D%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213985_13985.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213985_13985.png%22%20style%3D%22width%3A%20586px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117738i7C117798236063A5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2213985_13985.png%22%20alt%3D%2213985_13985.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E13985_13985.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Tried%20to%20debug%20twice.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Tried%20to%20debug%20twice.png%22%20style%3D%22width%3A%20586px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F45674iA4DFD7CF0F1F04BE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Tried%20to%20debug%20twice.png%22%20alt%3D%22Tried%20to%20debug%20twice.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ETried%20to%20debug%20twice.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E5%BC%80%E5%A7%8B%E6%96%B0%E7%9A%84%E8%B0%83%E8%AF%95%E4%BC%9A%E8%AF%9D%E4%B9%8B%E5%89%8D%EF%BC%8C%E5%8A%A1%E5%BF%85%E7%BB%88%E6%AD%A2%E7%8E%B0%E6%9C%89%E7%9A%84%E8%B0%83%E8%AF%95%E4%BC%9A%E8%AF%9D%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213986_13986.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213986_13986.png%22%20style%3D%22width%3A%20586px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117739iE8F241E2AF6A1FDE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2213986_13986.png%22%20alt%3D%2213986_13986.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E13986_13986.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Terminate%20Debug%20Session.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Terminate%20Debug%20Session.png%22%20style%3D%22width%3A%20586px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F45673i082C295434A2E8CB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Terminate%20Debug%20Session.png%22%20alt%3D%22Terminate%20Debug%20Session.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ETerminate%20Debug%20Session.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%9D%80%E6%AD%BB%E4%BB%BB%E4%BD%95%E5%83%B5%E5%B0%B8%EF%BC%9Agdb%20%E5%AE%A2%E6%88%B7%E7%AB%AF%E5%92%8C%E6%9C%8D%E5%8A%A1%E5%99%A8%E9%80%9A%E5%B8%B8%E5%9C%A8%E8%B0%83%E8%AF%95%E4%BC%9A%E8%AF%9D%E5%90%8E%E7%BB%88%E6%AD%A2%E3%80%82%3CSTRONG%3E%E7%BB%88%E6%AD%A2%3C%2FSTRONG%3E%E8%B0%83%E8%AF%95%E4%BC%9A%E8%AF%9D%E5%90%8E%EF%BC%8C%E8%AF%B7%E9%AA%8C%E8%AF%81%E8%BF%99%E4%BA%9B%E6%9C%8D%E5%8A%A1%E5%9C%A8%E4%BB%BB%E5%8A%A1%E7%AE%A1%E7%90%86%E5%99%A8%EF%BC%88Windows%EF%BC%89%E4%B8%AD%3CSTRONG%3E%E4%B8%8D%E5%86%8D%3C%2FSTRONG%3E%E5%AD%98%E5%9C%A8%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213987_13987.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213987_13987.png%22%20style%3D%22width%3A%20688px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117740i8ACDA88CC1079E2E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2213987_13987.png%22%20alt%3D%2213987_13987.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E13987_13987.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ARM%20GDB%20Client.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ARM%20GDB%20Client.png%22%20style%3D%22width%3A%20688px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F45670i461A0E1D92BAC480%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22ARM%20GDB%20Client.png%22%20alt%3D%22ARM%20GDB%20Client.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EARM%20GDB%20Client.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3COL%3E%3CLI%3E%3CSTRONG%3Earm-none-eabi-gdb.exe%EF%BC%9A%3C%2FSTRONG%3E%E8%BF%99%E6%98%AF%20ARM%20GDB%20%E5%AE%A2%E6%88%B7%E7%AB%AF%EF%BC%8C%E4%B8%8B%E9%9D%A2%E5%88%97%E5%87%BA%E7%9A%84%20OpenOCD%E3%80%81Segger%20%E5%92%8C%20P%26amp%3BE%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E9%9C%80%E8%A6%81%E5%AE%83%3C%2FLI%3E%3CLI%3E%3CSTRONG%3Eopenocd.exe%EF%BC%9A%E8%BF%99%E6%98%AF%20OpenOCD%20GDB%20%E6%9C%8D%E5%8A%A1%E5%99%A8%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3Epegdbserver_console.exe%EF%BC%9A%3C%2FSTRONG%3E%E8%BF%99%E6%98%AF%20P%26amp%3BE%20GDB%20%E6%9C%8D%E5%8A%A1%E5%99%A8%3C%2FLI%3E%3CLI%3E%3CSTRONG%3EJLinkGDBServerCL.exe%3C%2FSTRONG%3E%20%EF%BC%9A%E8%BF%99%E6%98%AF%20Segger%20GDB%20%E6%9C%8D%E5%8A%A1%E5%99%A8%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E7%9C%8B%E5%88%B0%E5%A4%9A%E4%B8%AA%E8%BF%99%E6%A0%B7%E7%9A%84%E5%83%B5%E5%B0%B8%2F%E5%AE%9E%E4%BE%8B%EF%BC%9A%E6%9D%80%E6%AD%BB%E5%AE%83%E4%BB%AC%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213996_13996.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2213996_13996.png%22%20style%3D%22width%3A%20684px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117741i5761A24A4DC9E1A5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2213996_13996.png%22%20alt%3D%2213996_13996.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E13996_13996.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22gdb%20Zombies.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22gdb%20Zombies.png%22%20style%3D%22width%3A%20684px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F45626i2F607687BCE31008%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22gdb%20Zombies.png%22%20alt%3D%22gdb%20Zombies.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Egdb%20Zombies.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CH3%20id%3D%22toc-hId--1852252425%22%20id%3D%22toc-hId--929564456%22%3E%E9%93%BE%E6%8E%A5%3C%2FH3%3E%3CUL%3E%3CLI%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%2211213%22%20data-containertype%3D%2214%22%20data-objectid%3D%22100705%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-100705%22%20target%3D%22_blank%22%3EKDS%20%E8%B0%83%E8%AF%95%E9%85%8D%E7%BD%AE%EF%BC%88OpenOCD%E3%80%81P%26amp%3BE%E3%80%81Segger%EF%BC%89%3C%2FA%3E%3C%2FLI%3E%3CLI%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%2211213%22%20data-containertype%3D%2214%22%20data-objectid%3D%22101792%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-101792%22%20target%3D%22_blank%22%3EFRDM-K22F%EF%BC%9A%E4%BD%BF%E7%94%A8P%26amp%3BE%20OpenSDAv2.1%E5%9B%BA%E4%BB%B6%E8%BF%9B%E8%A1%8C%E8%B0%83%E8%AF%95%3C%2FA%3E%3C%2FLI%3E%3CLI%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%2211213%22%20data-containertype%3D%2214%22%20data-objectid%3D%22101790%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-101790%22%20target%3D%22_blank%22%3EFRDM-K22F%EF%BC%9A%E4%BD%BF%E7%94%A8%20Segger%20J-Link%20OpenSDAv2.1%20%E5%9B%BA%E4%BB%B6%E8%BF%9B%E8%A1%8C%E8%B0%83%E8%AF%95%3C%2FA%3E%3C%2FLI%3E%3CLI%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222019%22%20data-containertype%3D%2214%22%20data-objectid%3D%22100720%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-100720%22%20target%3D%22_blank%22%3EOpenSDAv2%3C%2FA%3E%3C%2FLI%3E%3CLI%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fmcuoneclipse.com%252Ftag%252Ffrdm-k64f%252F%22%20target%3D%22_blank%22%3EFRDM-K64F%20%7C%20Eclipse%20%E4%B8%8A%E7%9A%84%20MCU%3C%2FA%3E%3C%2FLI%3E%3CLI%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fmcuoneclipse.com%252F2014%252F04%252F18%252Fcreating-new-eclipse-debug-configuration%252F%22%20target%3D%22_blank%22%3E%E5%88%9B%E5%BB%BA%E6%96%B0%E7%9A%84%20Eclipse%20%E8%B0%83%E8%AF%95%E9%85%8D%E7%BD%AE%20%7C%20Eclipse%20%E4%B8%8A%E7%9A%84%20MCU%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1114643%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E6%A6%82%E8%BF%B0%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114646%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8Kinetis%20Design%20Studio%E8%BF%9B%E8%A1%8CGDB%E8%B0%83%E8%AF%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114646%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20David%2C%3C%2FP%3E%3CP%3EEclipse%20GDB%20%E5%A6%82%E4%BD%95%E5%90%AF%E5%8A%A8%E8%B0%83%E8%AF%95%E4%BC%9A%E8%AF%9D%EF%BC%8C%E6%88%96%E8%80%85%E5%90%AF%E5%8A%A8%E7%9A%84%E4%BC%9A%E8%AF%9D%E5%A6%82%E4%BD%95%E6%A3%80%E6%9F%A5%E5%AE%83%E6%98%AF%E5%90%A6%E5%B7%B2%E7%BB%8F%E5%9C%A8%E8%BF%90%E8%A1%8C%EF%BC%8C%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E8%BF%99%E9%9C%80%E8%A6%81%E5%9C%A8%E6%8F%92%E4%BB%B6%E7%BA%A7%E5%88%AB%E5%AE%8C%E6%88%90%E3%80%82CodeWarrior%20%E5%B7%B2%E5%AE%9E%E7%8E%B0%E8%AF%A5%E5%8A%9F%E8%83%BD%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E8%87%AA%E5%B7%B1%E7%9A%84%E8%B0%83%E8%AF%95%E5%BC%95%E6%93%8E%E3%80%82%3C%2FP%3E%3CP%3E%E6%99%AE%E9%80%9A%E7%9A%84%20GDB%20%E5%90%AF%E5%8A%A8%E5%99%A8%E6%8F%92%E4%BB%B6%E4%B8%8D%E4%BC%9A%E6%A3%80%E6%9F%A5%E8%BF%99%E4%B8%80%E7%82%B9%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%AA%E7%9F%A5%E9%81%93%20GNU%20ARM%20Eclipse%EF%BC%88%E4%BD%8D%E4%BA%8E%20KDS%20v3.0.0%20%E4%B8%AD%EF%BC%89%E5%8F%AF%E4%BB%A5%E6%A3%80%E6%9F%A5%E6%98%AF%E5%90%A6%E5%B7%B2%E7%BB%8F%E6%9C%89%E8%B0%83%E8%AF%95%E4%BC%9A%E8%AF%9D%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%EF%BC%8C%E5%B9%B6%E6%8F%90%E4%BE%9B%E6%AD%A4%E5%AF%B9%E8%AF%9D%E6%A1%86%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%20style%3D%22width%3A%20378px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F54099i995EA1183C27C9CA%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_0.png%22%20alt%3D%22pastedImage_0.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_0.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BD%86%E5%AE%83%E4%BB%85%E9%80%82%E7%94%A8%E4%BA%8E%20Segger%20J-Link%EF%BC%88P%26amp%3BE%20%E5%92%8C%20OpenOCD%20%E5%B0%9A%E6%9C%AA%E5%AE%9E%E7%8E%B0%EF%BC%88%E5%B0%9A%E6%9C%AA%EF%BC%9F%EF%BC%89%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%E6%98%AF%E4%BD%BF%E7%94%A8%20J-Link%E3%80%82%E5%AF%B9%E4%BA%8E%20P%26amp%3BE%20%E6%88%96%20OpenOCD%EF%BC%8C%E6%82%A8%E5%BF%85%E9%A1%BB%E9%A6%96%E5%85%88%E7%BB%88%E6%AD%A2%E8%B0%83%E8%AF%95%E4%BC%9A%E8%AF%9D%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EErich%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114645%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8Kinetis%20Design%20Studio%E8%BF%9B%E8%A1%8CGDB%E8%B0%83%E8%AF%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114645%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%B8%BA%E4%BB%80%E4%B9%88%E5%9C%A8%E5%BC%80%E5%A7%8B%E6%96%B0%E7%9A%84%E8%B0%83%E8%AF%95%E4%BC%9A%E8%AF%9D%E4%B9%8B%E5%89%8D%E6%80%BB%E6%98%AF%E9%9C%80%E8%A6%81%E7%BB%88%E6%AD%A2%E4%B8%8A%E4%B8%80%E4%B8%AA%E8%B0%83%E8%AF%95%E4%BC%9A%E8%AF%9D%E3%80%82%E8%BF%99%E4%B8%8E%20Code%20Warrior%20%E4%B8%AD%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8D%E5%90%8C%E3%80%82%E6%9C%89%E4%BB%80%E4%B9%88%E5%8A%9E%E6%B3%95%E5%8F%AF%E4%BB%A5%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E6%88%96%E8%80%85%E4%BF%AE%E5%A4%8D%E5%AE%83%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114644%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8Kinetis%20Design%20Studio%E8%BF%9B%E8%A1%8CGDB%E8%B0%83%E8%AF%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114644%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%8F%AA%E6%98%AF%E8%AE%A4%E4%B8%BA%E6%8F%8F%E8%BF%B0%E4%B8%8A%E8%BF%B0%E8%BF%87%E7%A8%8B%E5%8F%AF%E8%83%BD%E6%9C%89%E5%8A%A9%E4%BA%8E%E4%B8%BA%20USBDM%20%E8%B0%83%E8%AF%95%E6%8E%A5%E5%8F%A3%E5%88%9B%E5%BB%BA%20GDB%20%E5%90%AF%E5%8A%A8%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fusbdm.sourceforge.net%2F%22%20title%3D%22http%3A%2F%2Fusbdm.sourceforge.net%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EUSBDM%EF%BC%9A%E7%94%A8%E4%BA%8E%20Freescale%20RS08%E3%80%81HCS08%E3%80%81HCS12%E3%80%81Coldfire%20%E5%92%8C%20ARM-Kinetis%20%E8%AE%BE%E5%A4%87%E7%9A%84%20USBDM%20%E8%B0%83%E8%AF%95%E5%99%A8%E6%8E%A5%E5%8F%A3%E3%80%82%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BD%BF%E7%94%A8%20USBDM%20%E6%96%B0%E9%A1%B9%E7%9B%AE%E5%90%91%E5%AF%BC%E5%88%9B%E5%BB%BA%E9%A1%B9%E7%9B%AE%EF%BC%8C%E5%88%99%E6%AD%A4%E8%BF%87%E7%A8%8B%E4%B8%8D%E6%98%AF%E5%BF%85%E9%9C%80%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%81%87%E8%AE%BE%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3EKDS%3C%2FLI%3E%3CLI%3E%E5%9C%A8%20KDS%20%E4%B9%8B%E5%90%8E%E5%AE%89%E8%A3%85%20USBDM%EF%BC%8C%E4%BB%A5%E4%BE%BF%E5%AE%89%E8%A3%85%E6%89%80%E9%9C%80%E7%9A%84%E6%8F%92%E4%BB%B6%E3%80%82%3C%2FLI%3E%3CLI%3E%E5%B8%A6%E6%9C%89%20USBDM%20%E5%9B%BA%E4%BB%B6%E7%9A%84%20FRDM-K22F%20%E6%9D%BF%E3%80%82%3C%2FLI%3E%3CLI%3E%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E5%BD%93%E5%89%8D%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%E7%9A%84%E7%8E%B0%E6%9C%89%E9%A1%B9%E7%9B%AE%EF%BC%88%E5%A6%82%E6%9E%9C%E9%A1%B9%E7%9B%AE%E5%88%9A%E5%88%9A%E5%88%9B%E5%BB%BA%EF%BC%8C%E5%88%99%E9%80%9A%E5%B8%B8%E4%BC%9A%E5%87%BA%E7%8E%B0%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%EF%BC%89%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3COL%3E%3CLI%3E%E5%9C%A8%3CEM%3E%3CSTRONG%3E%E9%A1%B9%E7%9B%AE%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%3C%2FSTRONG%3E%3C%2FEM%3E%E4%B8%AD%E9%80%89%E6%8B%A9%E9%A1%B9%E7%9B%AE%E5%B9%B6%E7%A1%AE%E4%BF%9D%E5%AE%83%E5%B7%B2%E6%88%90%E5%8A%9F%E6%9E%84%E5%BB%BA%E3%80%82%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_8.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_8.png%22%20style%3D%22width%3A%20166px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F17761iA53A532557EFB0B8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_8.png%22%20alt%3D%22pastedImage_8.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_8.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%E6%89%93%E5%BC%80%E8%B0%83%E8%AF%95%E6%8C%89%E9%92%AE%E6%97%81%E8%BE%B9%E7%9A%84%E4%B8%8B%E6%8B%89%E8%8F%9C%E5%8D%95%E5%B9%B6%E9%80%89%E6%8B%A9%3CEM%3E%3CSTRONG%3E%E8%B0%83%E8%AF%95%E9%85%8D%E7%BD%AE%3C%2FSTRONG%3E%3C%2FEM%3E%EF%BC%9A%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_20.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_20.png%22%20style%3D%22width%3A%20230px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F47036i0451A7BA45B2B56F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_20.png%22%20alt%3D%22pastedImage_20.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_20.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%E9%80%89%E6%8B%A9USBDM%E7%A1%AC%E4%BB%B6%E8%B0%83%E8%AF%95%E7%BB%84%EF%BC%8C%E7%84%B6%E5%90%8E%E4%BB%8E%E5%8F%B3%E9%94%AE%E5%8D%95%E5%87%BB%E8%8F%9C%E5%8D%95%E6%88%96%E5%AF%B9%E8%AF%9D%E6%A1%86%E9%A1%B6%E9%83%A8%E7%9A%84%E6%96%B0%E5%BB%BA%E5%9B%BE%E6%A0%87%E4%B8%AD%E9%80%89%E6%8B%A9%E6%96%B0%E5%BB%BA%E3%80%82%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_32.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_32.png%22%20style%3D%22width%3A%20344px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F47068i9ABFAFD67B51F7A2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_32.png%22%20alt%3D%22pastedImage_32.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_32.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%E6%89%93%E5%BC%80%E7%9A%84%E5%AF%B9%E8%AF%9D%E6%A1%86%E7%B1%BB%E4%BC%BC%E4%BA%8E%E6%A0%87%E5%87%86%20Eclipse%20%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%E3%80%82%E5%A6%82%E6%9E%9C%E4%B9%8B%E5%89%8D%E9%80%89%E6%8B%A9%E4%BA%86%E7%8E%B0%E6%9C%89%E7%9A%84%E6%AD%A3%E7%A1%AE%E6%9E%84%E5%BB%BA%E7%9A%84%E9%A1%B9%E7%9B%AE%EF%BC%8C%E5%88%99%E5%BA%94%E8%AF%A5%E6%AD%A3%E7%A1%AE%E5%A1%AB%E5%86%99%E7%AC%AC%E4%B8%80%E9%A1%B5%E3%80%82%E5%A6%82%E6%9E%9C%E9%9C%80%E8%A6%81%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E6%B5%8F%E8%A7%88%E6%8C%89%E9%92%AE%E9%80%89%E6%8B%A9%E5%85%B6%E4%BB%96%E6%9E%84%E5%BB%BA%E7%9B%AE%E6%A0%87%E3%80%82%E5%9C%A8%E6%89%80%E7%A4%BA%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%B8%AD%EF%BC%8C%E5%BD%93%E5%89%8D%E5%9C%A8%E6%9E%84%E5%BB%BA%E7%9B%AE%E6%A0%87%EF%BC%88%E9%80%89%E5%AE%9A%E7%9A%84%E9%A1%B9%E7%9B%AE%EF%BC%89%E4%B8%AD%E9%80%89%E6%8B%A9%E4%BA%86%3CEM%3E%3CSTRONG%3E%E8%B0%83%E8%AF%95%3C%2FSTRONG%3E%3C%2FEM%3E%E6%9E%84%E5%BB%BA%E3%80%82%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_41.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_41.png%22%20style%3D%22width%3A%20524px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F47067i33B5626EE237C71F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_41.png%22%20alt%3D%22pastedImage_41.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_41.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%E7%AC%AC%E4%BA%8C%E4%B8%AA%E9%80%89%E9%A1%B9%E5%8D%A1%E9%80%9A%E5%B8%B8%E9%9C%80%E8%A6%81%E4%BF%AE%E6%94%B9%E6%9C%80%E9%87%8D%E8%A6%81%E7%9A%84%E9%A1%B9%E7%9B%AE%E6%98%AF%E7%9B%AE%E6%A0%87%E8%AE%BE%E5%A4%87%E9%80%89%E6%8B%A9%E5%92%8C%E7%9B%AE%E6%A0%87%20Vdd%EF%BC%88%E4%BB%85%E9%80%82%E7%94%A8%E4%BA%8E%E5%8F%AF%E5%88%87%E6%8D%A2%E7%9B%AE%E6%A0%87%E7%94%B5%E6%BA%90%E7%9A%84%E7%9B%AE%E6%A0%87%EF%BC%8C%E4%BE%8B%E5%A6%82%20K22F%EF%BC%89%E3%80%82%E5%A6%82%E6%9E%9C%E9%9C%80%E8%A6%81%EF%BC%8C%E6%82%A8%E8%BF%98%E5%8F%AF%E4%BB%A5%E6%9B%B4%E6%94%B9%20GDB%20%E4%BD%BF%E7%94%A8%E7%9A%84%E5%A5%97%E6%8E%A5%E5%AD%97%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E6%83%B3%E4%BD%BF%E7%94%A8%E4%B8%A4%E4%B8%AA%20KDS%20%E5%AE%9E%E4%BE%8B%E8%B0%83%E8%AF%95%E5%A4%9A%E4%B8%AA%E7%9B%AE%E6%A0%87%EF%BC%8C%E5%88%99%E5%8F%AF%E8%83%BD%E9%9C%80%E8%A6%81%E8%BF%99%E6%A0%B7%E5%81%9A%E3%80%82%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_63.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_63.png%22%20style%3D%22width%3A%20668px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F47063iC93004578C771278%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_63.png%22%20alt%3D%22pastedImage_63.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_63.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%E6%82%A8%E7%8E%B0%E5%9C%A8%E5%BA%94%E8%AF%A5%E8%83%BD%E5%A4%9F%E4%BD%BF%E7%94%A8%3CSTRONG%3E%3CEM%3E%E5%90%AF%E5%8A%A8%3C%2FEM%3E%3C%2FSTRONG%3E%E6%8C%89%E9%92%AE%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FLI%3E%3CLI%3EUSBDM%20GDB%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E5%B0%86%E4%BD%9C%E4%B8%BA%E4%B8%80%E4%B8%AA%E5%8D%95%E7%8B%AC%E7%9A%84%E8%BF%9B%E7%A8%8B%E5%90%AF%E5%8A%A8%EF%BC%8C%E5%B9%B6%E5%85%B7%E6%9C%89%E8%87%AA%E5%B7%B1%E7%9A%84%20GUI%20%E7%AA%97%E5%8F%A3%EF%BC%9A%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_64.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_64.png%22%20style%3D%22width%3A%20403px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F47062i5FCF7EAC5BB96324%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_64.png%22%20alt%3D%22pastedImage_64.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_64.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%E5%90%AF%E5%8A%A8%E5%90%8E%EF%BC%8C%E5%8F%AF%E4%BB%A5%E5%9C%A8%E5%A4%96%E8%AE%BE%E8%A7%86%E5%9B%BE%E4%B8%AD%E6%A3%80%E6%9F%A5%E7%9B%AE%E6%A0%87%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_65.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_65.png%22%20style%3D%22width%3A%20647px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F47061iEE53BCB05BB54538%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_65.png%22%20alt%3D%22pastedImage_65.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_65.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EErich%20%E7%9A%84%E5%B8%96%E5%AD%90%E4%B8%AD%E7%BB%99%E5%87%BA%E7%9A%84%E6%9C%89%E5%85%B3%E6%95%85%E9%9A%9C%E6%8E%92%E9%99%A4%E7%9A%84%E8%AF%84%E8%AE%BA%E5%AF%B9%E4%BA%8E%20USBDM%20%E5%90%AF%E5%8A%A8%E5%90%8C%E6%A0%B7%E6%9C%89%E7%94%A8%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎08-11-2014 05:29 AM
更新人:
