TJA1043 application
TJA1043 application
loswe
你好,对于TJA1043的应用原理图(page 19)我有个疑问想请教:
TJA1043的INH引脚控制了给TJA1043的VCC引脚供电的5V电源芯片的使能引脚,那么当INH拉低5V电源芯片的使能引脚,5V电源芯片不能给TJA1043的VCC引脚供电,TJA1043没有供电,它如何输出INH信号来拉高5V电源芯片的使能呢
guoweisun
guoweisun
INH 是上拉到VBAT的,通过外部设置STB/EN来控制TJA1043的状态控制INH的H/L,他是一直受控的因为VBAT没断电,比方说上电VBAT以后 TJA1043工作在sleep的模式,STB/EN都是floating的无法唤醒他,那么可以通过本地wake pin 或者Remote wake-up (via the CAN bus)唤醒 让INH 拉高从而让TJA1043 工作:
Any wake-up request, setting the Pwon flag or a LOW-to-HIGH transition on STB_N will
clear UVNOM and the timers, allowing the voltage regulators to be reactivated (at least until
UVNOM is set again).
guoweisun_0-1753941245889.pngguoweisun_0-1753941245889.pngguoweisun_1-1753941263720.pngguoweisun_1-1753941263720.png
loswe
常电应用场景中VBAT是不断电的,按照参考应用原理图,本地wake pin是通过电阻上拉到VBAT的,那wake pin始终是高电平,是不是就不能用来控制唤醒。
via the CAN bus的话,TJA1043的VCC没有供电,它可以收到CAN bus的唤醒报文吗。
guoweisun
Sleep 模式VCC本来就没电了
您仔细看看AH1014 page45:6.2.4 Sleep Mode
Application Hints
loswe
您给的资料中提到了While the microcontroller is completely un-powered (no VCC supply),
the TJA1043 keeps partly alive via its battery supply. It allows the transceiver to monitor
the bus for CAN messages。我理解这就是TJA1043可以在没有VCC的情况下继续监听总线报文的原因吧
guoweisun
对的
loswe
谢谢
%3CLINGO-SUB%20id%3D%22lingo-sub-2144170%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ETJA1043%20application%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2144170%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20I%20have%20a%20question%20about%20the%20application%20schematic%20of%20TJA1043%20(page%2019)%3A%3C%2FP%3E%3CP%3EThe%20TJA1043's%20INH%20pin%20controls%20the%20enable%20pin%20of%20the%205V%20power%20supply%20chip%20that%20supplies%20power%20to%20the%20TJA1043's%20VCC%20pin%2C%20so%20when%20INH%20pulls%20down%20the%20enable%20pin%20of%20the%205V%20power%20supply%20chip%2C%20the%205V%20power%20supply%20chip%20can't%20supply%20power%20to%20the%20TJA1043's%20VCC%20pin%2C%20and%20there%20is%20no%20power%20supply%20to%20the%20TJA1043%2C%20so%20how%20can%20it%20output%20the%20INH%20signal%20to%20pull%20up%20the%20enable%20of%20the%205V%20power%20supply%20chip%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2144797%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TJA1043%20application%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2144797%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3Ethank%20you%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2144796%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TJA1043%20application%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2144796%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3Eright%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2144794%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TJA1043%20application%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2144794%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E7%BB%99%E7%9A%84%E8%B5%84%E6%96%99%E4%B8%AD%E6%8F%90%E5%88%B0%E4%BA%86While%20the%20microcontroller%20is%20completely%20un-powered%20(no%20VCC%20supply)%2C%3CBR%20%2F%3Ethe%20TJA1043%20keeps%20partly%20alive%20via%20its%20battery%20supply.%20It%20allows%20the%20transceiver%20to%20monitor%3CBR%20%2F%3Ethe%20bus%20for%20CAN%20messages%E3%80%82%E6%88%91%E7%90%86%E8%A7%A3%E8%BF%99%E5%B0%B1%E6%98%AFTJA1043%E5%8F%AF%E4%BB%A5%E5%9C%A8%E6%B2%A1%E6%9C%89VCC%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E7%BB%A7%E7%BB%AD%E7%9B%91%E5%90%AC%E6%80%BB%E7%BA%BF%E6%8A%A5%E6%96%87%E7%9A%84%E5%8E%9F%E5%9B%A0%E5%90%A7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2144523%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TJA1043%20application%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2144523%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3ESleep%20mode%20VCC%20was%20already%20dead.%3C%2FP%3E%0A%3CP%3ETake%20a%20closer%20look%20at%20AH1014%20page45%3A%206.2.4%20Sleep%20Mode%20%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com.cn%2Fdocs%2Fen%2Fsupporting-information%2FAH1014_v1_4_Application_Hints_TJA1042_43_48_51.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EApplication%20Hints%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2144302%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TJA1043%20application%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2144302%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EThe%20VBAT%20is%20not%20powered%20on%20in%20the%20constant%20power%20application%20scenario%2C%20and%20according%20to%20the%20reference%20application%20schematic%2C%20the%20local%20wake%20pin%20is%20pulled%20up%20to%20the%20VBAT%20through%20a%20resistor%2C%20so%20the%20wake%20pin%20is%20always%20high%2C%20so%20is%20it%20not%20used%20to%20control%20the%20wake%20up.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EIf%20the%20TJA1043%20is%20not%20supplied%20with%20power%20at%20VCC%20via%20the%20CAN%20bus%2C%20can%20it%20receive%20a%20wake-up%20message%20from%20the%20CAN%20bus.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2144235%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TJA1043%20application%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2144235%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%0A%3CP%3EINH%20%E6%98%AF%E4%B8%8A%E6%8B%89%E5%88%B0VBAT%E7%9A%84%EF%BC%8C%E9%80%9A%E8%BF%87%E5%A4%96%E9%83%A8%E8%AE%BE%E7%BD%AESTB%2FEN%E6%9D%A5%E6%8E%A7%E5%88%B6TJA1043%E7%9A%84%E7%8A%B6%E6%80%81%E6%8E%A7%E5%88%B6INH%E7%9A%84H%2FL%2C%E4%BB%96%E6%98%AF%E4%B8%80%E7%9B%B4%E5%8F%97%E6%8E%A7%E7%9A%84%E5%9B%A0%E4%B8%BAVBAT%E6%B2%A1%E6%96%AD%E7%94%B5%EF%BC%8C%E6%AF%94%E6%96%B9%E8%AF%B4%E4%B8%8A%E7%94%B5VBAT%E4%BB%A5%E5%90%8E%20TJA1043%E5%B7%A5%E4%BD%9C%E5%9C%A8sleep%E7%9A%84%E6%A8%A1%E5%BC%8F%EF%BC%8CSTB%2FEN%E9%83%BD%E6%98%AFfloating%E7%9A%84%E6%97%A0%E6%B3%95%E5%94%A4%E9%86%92%E4%BB%96%EF%BC%8C%E9%82%A3%E4%B9%88%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E6%9C%AC%E5%9C%B0wake%20pin%20%E6%88%96%E8%80%85Remote%20wake-up%20(via%20the%20CAN%20bus)%E5%94%A4%E9%86%92%20%E8%AE%A9INH%20%E6%8B%89%E9%AB%98%E4%BB%8E%E8%80%8C%E8%AE%A9TJA1043%20%E5%B7%A5%E4%BD%9C%EF%BC%9A%3C%2FP%3E%0A%3CP%3EAny%20wake-up%20request%2C%20setting%20the%20Pwon%20flag%20or%20a%20%3CSTRONG%3ELOW-to-HIGH%20transition%20on%20STB_N%20will%20%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Eclear%20UVNOM%20and%20the%20timers%3C%2FSTRONG%3E%2C%20allowing%20the%20voltage%20regulators%20to%20be%20reactivated%20(at%20least%20until%20%3CBR%20%2F%3EUVNOM%20is%20set%20again).%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22guoweisun_0-1753941245889.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22guoweisun_0-1753941245889.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F350391i3BAAC96B728AE68F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22guoweisun_0-1753941245889.png%22%20alt%3D%22guoweisun_0-1753941245889.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eguoweisun_0-1753941245889.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22guoweisun_1-1753941263720.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22guoweisun_1-1753941263720.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F350392i01C07A392565CC9B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22guoweisun_1-1753941263720.png%22%20alt%3D%22guoweisun_1-1753941263720.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eguoweisun_1-1753941263720.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
