S32DS compilation error
3,880 次查看
leeli
S32DS compilation error program "gcc" not found in PATH; but it can be compiled and passed, what is the reason for this?
标记 (1)
3,171 次查看
yinzc
Hi,i have the same problem,have you solved the problem now?
3,829 次查看
nxf57422
did you run export PATH=<path for gcc> ? Can you add build logs for additional info, thanks
Best,
Marco Cesarano
